Question about Likom ViewMate LP995 (White) 19 in.CRT Conventional Monitor
Likom LP995 bad color and can not view menu
I have an old Likom LP995 monitor and the color is bad. I push the menu button on monitor to adjust color and it comes up completely black. I can not see the menu options to to get to the appropriate option to adjust. The menu is working but is all blacked out so I have to try each option until I get to the color option. Anyway to restore the menu so I can see it??
3 Suggested Answers
  • 125 Answers
SOURCE: The monitor cant view video
To use the external vga connector of a laptop, you have to activate it. In many notebooks it is Funtion and F7 (Fn-F7). In your notebook it may be F5 or F6, look for a monitor sigh in the F keys. The activation may sometimes rotate in sequence , ie, External + LCD, LCD, External... and so on.
Posted on May 15, 2007
  • 125 Answers
SOURCE: Arcing around neck board
There is a crack in the neck of the tube and the vacuum inside is lost. There is already air inside the tube that is why the sparks are going to the pins. The TV must have been dropped or someone accidentally hit the neck of the tube
Posted on May 31, 2007
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
I have problems viewing dark websites. My screen dim's, I can still read everything, it's just very dark. It also makes a humming noise. Is it something I can adjust. Cheers, Michelle
There is a small row of buttons on the bottom right of the front panel of the monitor. From these buttons it's possible to adjust: Gamma correction, Brightness, Color balance, H/V position, Color temperature, and Contrast. By pushing the menu button your choices should be diplayed on screen. If there is a choice of "factory default" try that and it will take all adjustments back to as they were when it was set up when new. You won't find buttons to match the adjustments I mentioned above. There may be just 3 buttons but by way of the on screen menu they are enough to acheive what you want.
From past experience I'd say it's possible someone has been playing around with the buttons and upset it's settings.
If you continue to have problems I can download the manual and guide you from there.
Apr 25, 2010 | Samsung SyncMaster 2253BW LCD Monitor
Monitor screen too dark. Some things aren't even visible
Adjust your monitor Brightness and Contrast and make sure you set it high enough to be able to view text and images. Refer to the monitor manual.
Nov 15, 2009 | Likom Futura LD7 17" CRT Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Blinking main menu of the monitor!
i also have the same problem dude,these f...ing view sonic doesnt support customers,specially for asia..........please help me ,i am very poor and i cant buy another one........please help me brothers........mail me djarunagamage@yahoo.com
thank you and god blesses you all.........greets from sri lanka
Jul 11, 2007 | ViewSonic 17" CRT Monitor
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
May 15, 2007 | Likom HD15A 15" LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Likom ViewMate LP995 (White) 19 in.CRT Conventional Monitor Logo
46 people viewed this question
Top Likom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
