Question about Dell Inspiron 1521 Notebook
CDRom is not present in Vista 32 - Shows driver not working...
The drivers are present but seems to be a registry error.
Like modified or deleted referances.
Any help would be appreciated!
Thanks
  • cciangelo Dec 18, 2008
    To repair this problem go to the regestry to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\4D36E965-E325-11CE-BFC1-08002BE10318
    Now delete the UpperFilter and LowerFilter references.
    Reboot your computer and it should work..
    Good Luck
    Scholar:
  • 55 Answers
Check "Computer" or My Computer and see if the drive is there. If not, reboot the system and go to the System Setup page (hit F2 on the Dell splash screen). Check if the CDROM drive is present under Drive Configuration. If not, reseat the CDROM drive. Remove it from the computer and just put it back in. If you think this is a software issue, backup all your files to a USB flash drive and do an image restore. Hit F8 several times continuously when you see the Dell Splash Screen then select Repair Your Computer. Login on the System Recovery Page. Choose Dell Factory Image Restore. This will bring your computer back to where it started.
Please rate this if this helps.
Posted on Dec 18, 2008
Need Help, Dell desktop inspiron 530s, Code 10 CD won't start. Yellow ! in device manager, checked for solutions, latest driver installed. I installed a new drive and concern still present. Both connectors...
Hi!
I assume you are using Windows Vista. To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue .
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters , and then click Delete .
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters , and then click Delete .
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Thanks for reading my suggestion and I hope this helps.
Apr 17, 2011 | Dell Inspiron 530s Desktop Computer
Hey guys im having problems with my sony dvd drive. I recently installed windows 7 due to my vista completely turning to ****. I understand that the OS is still new and there is a lot that needs to be...
You may try with these troubleshooting steps.
These steps are applicable for either Windows XP or Vista OS. But you can perform the same in the Windows 7 OS.
Option 1: Try installing Sony Registry Update for CD/DVD Drives:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR180E&upd_id=2031&os_id=28
Option 2: Try deleting UpperFilters and LowerFilters Registry values as mentioned:
http://support.microsoft.com/?id=314060&SD=SONY
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C299114
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C501168
The exact solution is delete the UpperFilters and LowerFilters Registry values and then restart the Computer.
Good Luck!!!!!!!!!!!!!!!
Sep 12, 2009 | Sony VAIO VGN-NR180EW Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
from your description, it's windows problem.
You can either reload your operating system or edit the windows registry.
To edit the windows registry follow this step from Microsoft:
http://support.microsoft.com/kb/314060
Oct 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Lost driver thro error code 39 dvd/cd rom drive
Dear sir/madam,
you can solve this by using the following links,
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
http://www.vistax64.com/vista-hardware-devices/113566-cd-dvd-rw-error-code-39-a.html
thank you,
Aug 23, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Both cd drive are missing in "My Computer" say it is not working properly or is not presant. Give a Code 10 error
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code is the same with error code 10 which means "Windows cannot load the device driver fro this hardware. The driver may be corrupted or missing (code39)".
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
3. In the right pane, right-click UpperFilters, and then click Delete.
5. In the right pane, right-click LowerFilters, and then click Delete.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Jul 30, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Driver problem
I also have the same problem my cd is working not DVD
Jul 08, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
NONWORKING CD ROM
try to look for a firmware update for your cdrom and try to reload the drivers for that. your cdrom may just need an update from the manufacturer.
Mar 12, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
Thanks
Feb 22, 2008 | Acer Aspire 5630 Notebook
i believe it's software problem, you can reload the operating system using alt+f10 or you can try this
Feb 16, 2008 | Acer Aspire 5610-4648 Notebook
Dell Inspiron 1521 Notebook Logo
118 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
