Question about Lexmark E250dn Laser Printer
Reset Lexmark E250dn IP address
Hi ,
I have a new Lexmark printer here, but I get no communication.
The current IP address is set to 0.0.0.0, how can I change it to 192.168.1.1?
  • scottm837 Jan 29, 2009
    Yes, but how do you actually change the IP address in the printer? The manual that came with it doesn't seem to say this anywhere.
  • Anonymous Apr 22, 2009
    I am unable to connect to the printer web page to change the settings since the IP address of the printer is not accessible.
    President:
  • 1,073 Answers
Yes you can, but you need to lock that ip in your router to so its always goes to your printer.
Just make sure that your router dosent use that ip for it self, the usal ip for a router is 192.168.0.0 or 192.168.0.1, but you never know. Check it to be shure!
Posted on Dec 18, 2008
  • filip82 Feb 25, 2011
    if printer IP address is accidentally set to 0.0.0.0 AND autoconf is disabled AND DHCP is disabled, then you are toast, because:
    - reset to factory defaults does not reset network settings
    - IP, autoconf ,DHCP cannot be manipulated trough LED menu
    - access with network is IMPOSSIBLE because no TCPIP stack can address 0.0.0.0 by definition
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
Pc and communication with printer
If your printer is already connected to your network, try to assign a static IP address to your printer to prevent it from getting a new IP address from your router. To do that, just get the IP address of your printer, open a browser and type in the IP in the address bar of your browser. Once you have the embedded web server of your printer, click on Settings > Network Ports > TCP/IP > Uncheck "Enable DHCP" > Submit.
Once you have set a static IP, resintall the Lexmark software. It would be best to use an updated driver. Just go to http://bit.ly/VuhrpF to download the updated driver. After reinstalling the driver, check if the firmware for your printer is up to date. Just go to http://bit.ly/PZaAmK to download the firmware update.
Jan 22, 2013 | Lexmark S315 90T3100 All-in-One Color...
I can't access to the menu of the printer from the browser
Please print a network settings page to check status if it is connected. To print network set up page click the link http://bit.ly/pvTBgZ
Please take note of the IP address and type it on your browser
Jul 14, 2011 | Lexmark E250dn Laser Printer
E250dn TCP/IP: Actif: yes Adress: 0. 0. 0. 0
What you need to do is reset the Network Settings, to do this please click on the link http://bit.ly/kR1jke
Please contact Lexmark Technical Support for additional assistance
Jun 29, 2011 | Lexmark E250dn Laser Printer
How do i set the ip address for e250dn
Follow these steps: 1. Press the "Operator Panel" button to print a Network Setup page.
2. Locate the entry labeled "UAA" or "Physcal Address."
3. Write down the 12-digit address. An example is "00:1A:2B:3C:4D:5E."
Set the IP Address 1. Insert your Lexmark drivers CD and select "View Documentation."
2. Select "Software and Utilites" and click "IP Setup Utility" to start the program.
3. Enter the physical address for the printer in the "Discover Print Servers" field and click "Discover."
4. Select the printer from the "Configure Print Servers" list and click "TCP/IP Settings."
5. Click "Suggest Address" if you'd like the utility to locate an available IP for you, or enter the IP of your choice in the "IP Address" field and click "OK.
May 22, 2011 | Lexmark E250dn Laser Printer
I have recent6ly had to have a new router and since then the Lexmark X6570 printer we have won't work,I have concluded that the ip address needs changing to the current one but don't know how to do...
Try to reset the wireless network adapter of the printer. On the printer operator panel:
- Press Settings to display Settings
- Press pattlnk_5182007_1524-left_new.jpg to display Settings
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Network Setup
- Press pattlnk_5182007_1529-right_arrow.jpg to display Network Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Wireless Setup
- Press pattlnk_5182007_1529-right_arrow.jpg twice to display Wireless Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display the scrolling message This will reset all wireless network adapter settings. Are you sure?.
- Press pattlnk_5182007_1524-left_new.jpg or pattlnk_5182007_1529-right_arrow.jpg to change the value from No to Yes, and press pattlnk_5152007_204-checkmark_alone.jpg.
The WiFi light on the printer will momentarily turn off. When it lights up solid orange, launch the Lexmark Wireless Setup Utility on your computer by inserting your installation cd or executing the Lexmark X6570 driver. Follow the instructions on your computer screen.
May 05, 2011 | Lexmark X6570 InkJet Printer
How do I find out the IP Address of my school's Lemark E250dn printer?
You can print the network setup page to view the Lexmark E250dn's IP address. Visit the Lexmark at http://bit.ly/9kdDvc for the instructions on how to print the network setup page. Thanks.
Sep 28, 2010 | Lexmark E250dn Laser Printer
I have a Belkin router N300 do I just plug in the printer Lexmark cable to the router and that is it.
To make my Lexmark e250DN work on the network using my new Belkin N300, I had to do this:
1. Install router as per Belkin instructions. 2. Power off printer, then connect Lexmark printer to the router. Power on printer. 3. In a Browser, go to 192.168.2.1 which is the Router's IP address. 4. Click on DHCP Client List. You will see a list of the "computers" connected to the router, which includes the printer. Your printer will have a very long alphanumeric Host Name (mine began with E00000) Note the IP address (something like 192.168.2.4) That is the printer's IP address. 5. In Control Panel, Printers & Faxes, a) if the printer was previously installed with a different router, edit its settings to use the new IP address; b) if the printer was not previously installed, ADD a Network Printer at address http://192.168.2.x (x being whatever your DHCP client list showed).
That should do it.
Jun 25, 2010 | Belkin (F5D7230-4) Router (587009)
Lexmark E250dn Laser Printer Logo
3,598 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
