Question about Sony KDS-R60XBR1 60" Projection HDTV
Blue discoloration I have a sony lcd projection tv. When Im watching tv, theres this blue discoloration in the background. When the screen shows bright pictures thats when you can see that blue background. If theres no bright picture, the tv looks regular. If I was watching a movie with a sky background or a movie with snow, you would be able to see that blue discoloration in the background.How do I fix the problem?
    Novelist:
  • 192 Answers
I have replaced alot of these light engines for this problem. Yesterday I received a letter from Sony saying they are going to give an additional warranty to have the optics replaced. I just checked, your model is one of them and Sony is replacing the optic block under an extended warranty, regardless of the purchase date, until the end of October 2008. Contact Sony for an Authorized Service Center in your area or go to this site to read about it: http://esupport.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR60XBR1 Have this repair done on your set and it should save you about $1300.00 to $1500.00 on the repair. Hope this helps.
Posted on Apr 01, 2007
SOURCE:
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The screen is green and blinks
Hi,If there's any discoloration,pixilation or hues on the tv it will be an issue w the light engine's 3 lcd chips.This link explains how the lcd technology works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and picture by blending together all when the light of the lamp goes through them.When they start to melt they will start to show the symptoms.You will need to replace the 3 lcd chips or replace the light engine.Good luck and God bless your house!
Feb 10, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow/green blotch appears in light areas
Feb 10, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv just turns off while watching it the screen goes blue than turns off
This is one of a group of sets (KP-57ws500) that had bad picture tubes---all of them had this trouble.
The picture tubes are no longer available from Sony--only available on a rebuild basis from another company--very expensive and usually not worth doing---blue is most common tube to show trouble.
The set is shutting down because if the screen goes bright blue---it pulls too much current and the set goes into protective shutdown.
There is one fairly easy thing that you may be able to do-----I have done it before.
What it entails is getting at the Screen/ Focus control block and turning the Blue Screen control down--if it works it may just buy you some time but I have seen several sets where it allowed the set to have some more life.
Usually if the set was working the way this problem begins is you on a blank video input notice a slight blue color in the background with some faint curved lines visable.
If you want to attempt to do the adjustment--let me know and I will tell you how.
I am here to help people----I have seen over 100 of these Sony sets with this problem---replaced tubes in many of them when they were new or under warranty.
SD TECH
Oct 26, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue line across top of my Sony XBR 60
KDF-60XBR950 replaced bulb, but no picture. It DOES have a solid green light when on.
Jul 21, 2009 | Sony Televison & Video
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Yellow tint on screen, little bright spots on the dark blue.
http://repairs.sunnyoasis.com/sonylcdtv/ this is a link on what to do i had same problem picture is like brand new now good luck this takes about 3 to 4 hrs
Dec 26, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KP%&HW40 with varying background tinting
YOU HAVE 6 ADJUSTMENT BEHIDE THE SPEAKER SCREEN. THERE ARE TWO SCREWS YOU NEED TO REMOVE. ADJUST JUST THE MIDDLE BOTTOM SLOWLY. IT SHOULD CLEAR YOUR PICTURE. IF IT DOES NOT WORK IT MAYBE YOUR GREEN CRT. THIS TV IS GARBAGE. IM TRYING TO GET 100 PEOPLE CALL SONY APRIL 17,2008 AND GTHEN SEND TGHEM A LETTER AND AFTER CONTACT YOU LOCAL MEDIA FOR THIS DEFECT. SONY HAS TO PAY YOU BACK OR REPLACE THIS TV.
Feb 23, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KDS-R60XBR1 60" Projection HDTV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
