Question about StarTech.com StarView SV211K 2-port KVM Switch
Codes don't work
I have put the new codes into the box, and my box is still saying codes need updating, i have turned it off and on and still no good. Has anyone any idea if i need to do anything else, this happened the other day also, so i had to power scan and re do all channels, it looks like i am going to have to do this every time unless anyone has any idea.
thanks
  • 1 more comment
  • mishhd Dec 18, 2008
    all my codes have gone again and i havn't got the bottom set and my key update has gone back to 4 December, could you explain a little clearer (step by step) what to do I am a little thick when it comes to this box, its only lately had these problems usually codes go in and its up and running straight away
    thanks
    have yu got bottom set of codes
    I already have this toolbar, but what do i have to do to update the firmware, as i said I am not up on this kind of thing so need step by step instructions.
    thank you ever so much for your help
  • maxi3 Dec 18, 2008
    starview codes
    Sergeant:
    Champion:
  • 293 Answers
Once you are into the menu screens the Nagravision screen will come up look down the list and make sure your EMU is set to ON.?
In the code screens make sure the provider ID is set to your provider?.
when you change the codes store each code entered then exit out .
hope this is helpful to you.
Posted on Dec 18, 2008
  • igb_41 Dec 18, 2008
    you will have to update the firmware in your box , this link will give you a toolbar that has updates for most box's give it a try and let me know if you need any more help.
    http://www.thechatterbox.cc/
2005 PT CRUISER LIGHT ON DASH SAYS NO FUSE RADIO DON'T WRK DOOR LOCKS DON'T WORK INTERIOR LIGHTS DON'T WORK
I hve the same problem go under the hood for the fuse box you will c a fuse that has a blk clip around the whole fuse it self to open it use a small screw driver the ones u use for ur glasses nd open it c if it needs to be changed out if good jst unplug it nd c wat it does on my car I jst unpluged it nd now everything working I think its called a iud some wired name but u can't miss it good luck
Nov 03, 2012 | 2005 Chrysler PT Cruiser
How do I play a blu ray DVD on my PS3. I am not hooked to the internet. It is saying that I need a new encryption key. What can I do to watch this Dvd?
You need to update your PS3 software, which should also update your encryption keys. I understand that you don't have internet, but do you have a friend, etc. with internet where you could take your console to?
The reason for this: encryption codes are updated to enhance security of the discs (in an attempt to prevent copying, etc) but also new codes are added when new movies are released.
Unfortunately, these updates are periodic, and will probably need to be done once or twice a year. Good luck.
May 30, 2011 | Sony Playstation 3 (PS3) Console
Codes for telewest north east march 2010
You will need to reset your starview box to factory settings first which can be done through the main menu, type 0000 when prompted for code.
Reboot the box as you did when you first got it.
Don’t forget to turn “Key EMU” back on as this will have changed to off with the reset (1570 from the menu screen).
This should have cured all your problems!!
If this still doesn’t work you will need to input new codes via Nagravision (also 1570 from the menu screen).
PROVIDER CODE: 5A 01
KEY 00 = CF 53 0C 33 79 61 71 85
KEY 01 = 52 5E 8D 45 FC 75 F6 4A
There is a rumour on the streets that Telewest are soon to dump Nagravision and send out all Telewest users new cards!
Don’t know if this will ever happen, but if it does how will we enter new codes???
Mar 11, 2010 | StarTech.com StarView SV211K 2-port KVM...
Need codes for 16th jan 10 thanks telewest
TELEWEST CODES 21/1/2010
5A 01
Put These Code Then Factory Reset Every Thing Will ALL Good
Jan 16, 2010 | StarTech.com StarView SV211K 2-port KVM...
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Ntl codes
Hi Adrian,
Well first, here are the latest codes:
Basically, I think you should flash with the latest firmware and fix. Here is a guide to doing, on the Box Super:
http://www.freewebs.com/boxsuper/
You say it keeps updating? Has it never even scanned a number of channels, and then you have exited out back to tv? Sometimes you have to flick it on and off a channel such as Sky Sports or Setanta, to get the code update to 'kick in', even while you think the transponders are still updating (frequencies being detected and allocated to your box)when in fact there are many transponders that do not even transmit.
Then you enter 1570 and scroll down to EMU and click right to turn it on. Then exit to tv.
Sometimes you have to flick a channel on and off or even the box itself to 'kick' the code update on a bit. Sounds crude I admit, but works for many..
I know this is a lot of info to fry your brain, but the more your play with it all, the more you'll learn and eventually you'll just flash and fix and won't have to enter your codes so often.
As for the latest codes, firmware and fixes, you can get them all on a handy toolbar here. The codes are on the Keymaster which you can install from the toolbar 'Big Key' thingy.
Hope this helps
Chris (ziraffa)
ps The codes are also on the BigmaQ toolbar.
Jan 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Cant get on the page to enter the new code
Google the bigMAQ toolbar and install it. There is an icon on thistoolbar 'Latest Keys' - make a note of the keys for your provider.
Now you need to manually update the keys on your box by:
press menu-yellow
3 lines will appear
provider
ntl-5401
tw-5a01
ex cw-5c01
enter the keys were it says
key 00 ** ** ** ** ** ** ** **
key 01 ** ** ** ** ** ** ** **
if your not sure of your ex provider check here List of Net Id's for Cable TV
Next, press menu, installation,user installation,(if it asks for a pin use1004). Press yellow button and do a full powerscan on your providersymbol rate, 6887 for N*L, 6952 for others.
When scan completes, exit back to user installation, you should now seea lot of frequencies, (Transponders), press red button to update channels.Screen will go blank for a minute,it will then pull in the channels foryou. After scan exit all the way out to view channels.
If it says updating codes put it on Sky sports and let it update.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Games won't work
the problem lies within your hard drive. first thing youll have to do is perform a matenince on the hard drive. to perform this you must go into settings, memory, select your hard drive, then enter the following code... LB LB X X RB RB... it will say are you sure you want tot perform this. select yes... when this is done and the games still dont work, you'll have to format your hard drive. and after youve done that and they still dont work, you'll then have to buy a new hard drive
Oct 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 update
i,m assuming that you have a hard-drive, and this is a premium x-box 360 ?
it,ll only work with the hard-drive attached.
If you go to xbox.com theres all the information you need there.
you have 3 options. 1 is to update via x-box live.
2. you can download the file, and burn the image.
3. order a disk via mail.
If you have any problems, obtaining the CD. please leave me your e-mail address here.
And i,ll send you 1 FREE Of charge.
If you don,t have a hard-drive. thats definately the problem.
****Don,t forget to rate this solution accordingly****
Our status as experts on Fixya. are dependent on good ratings.
Any further problems, please feel free to contact me.
Mike @ Compurepair.
May 01, 2008 | Microsoft Xbox 360 Console
StarTech.com StarView SV211K 2-port KVM Switch Logo
44 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
