Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
Epson rx620-waste ink pad replacement Instructions
Looking for instructions on how to open the printer and replace the waste ink pads.
  • 4 more comments
  • sandysun Dec 18, 2008
    The manual does not show how to replace waste ink pads.
    That shows how to replace the ink cartridges--I need to replace the WASTE INK PADS.
  • sweetdog Jan 27, 2009
    I have same problem - need to replace ink pads on Epson RX 620 - solution posted  sounds very complicated  for novice- especially without  visual instructions. Any visuals out there? VA
  • graway7420 Apr 07, 2009
    Hi, where does a person buy the INK PADS? Is the cost of these ink pads expensive compared with buying a new unit?
  • Anonymous Mar 16, 2014
    contact Epson support to replace ink pads
    what do you do now
    President:
  • 1,073 Answers
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Posted on Dec 18, 2008
  • Nicolas
    Nicolas Dec 18, 2008
    It does, read page 55
    Good luck to you
  • Nicolas
    Ah! sorry M8! my mistake!
    Cant find any manual about that, but i found how to do it.
    Here is how to do it then!
    Be extremely careful so as to not damage any of the data cables. Remove the control panel then the scanner assembly. Disconnect all cables from the circuit board (you may have to remove the board), and unscrew and lift off the upper housing. They are all held by visible screws and tabs. Then remove the sheet feed assembly (don't forget the screw on the underside and on the left by the gear assembly. Remove all screws holding the printer to the lower case (two screws are hidden under the scanner hinges). Next disconnect the drain tube coming off the pump. Finally remove the printer mechanism. The waste ink pads are now clearly visible.
    Hope this helps.
    I hope that answer is better then my last one:)
    Good luck to you
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
What do I do to fix when my RX620 Epson printer tells me that parts within have come to the end of service life?
fault is caused by counter, which counts printed pages for reason of possible overflow of waste ink pads. To reset counter a free tool is available under::
this tool has also other advantages of e.g. overdubbing cartridge codes ....
a german instruction for resetting the counter is available here:
http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen
make sure to have removed and replaced waste ink pads:
http://www.octoink.co.uk/pages/Epson-RX620.html
start program, choose printerport which is used for Epson rx620, choose Epson model rx620
close active window of program ssc -> program will be available by icon in right lower corner.
switch on printer
right mouse click on program icon in right lower corner will open options:
http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen#
choose according to picture
switch off printer / switch on printer
in case of not working at once retry
Jul 14, 2012 | Epson Stylus Photo RX620 All-In-One InkJet...
I was told that I need to replace my ink pad on my epson stylus RX620 & I am trying to find out how much they are . Is this something my husband could do or can I get A reliable computor man to do...
If it is your waste ink pad that is full and needs replacing you can take it to the nearest Epson service centre and have it done the charge is usually about £50-£60 If your husband is good with printers he could strip it down using the service manual and clean the pads himself but he will also need a reset utility to restet the printer when he is finished If your printer is not a new model you may find a reset utility free on the internet
Apr 03, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Need to replace ink pads for epson stylus rx620.printer. Where to buy and how to replace?
You don't need to buy the pad. Just wash with hot water. Is there a message to replace waste ink pad?. You need to reset waste ink counter. Use SSC utility to reset it. Extend outlet pipe to outside. You don't need clean pad again. If you wish to wash or replace pad, you must open case and diasemble all mechanics. Find SSC at indoreset.blogspot.com. And printer diagram at printersiam.com
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Re.ink pad
Waste Ink Pads. They need to be cleaned/replaced and the counter reset. Look at the Ink Waste Container kits here. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Stylus Photo 1400 Ink Pad Replacement
Hi, if you change wast ink pads it will cost too much.
The best way to resolve this matter is Do it by your self.
You can purcahse wast ink bottle from us then use EPSON reset software to reset wastink pads.
After this done your printer will back to normal.
If you require more information related this issue you can email us free of charge
service@rextras.com
Kind Regards
May 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Service required parts inside your printer are at the end of there service life.seer your printers documentation for details
Hi, I had the same problem with my RX500.
All you need to do is perform a reset, by pressing and holding the "Stop", "B&W", and "Power" buttons all at the same time and holding them down for at least 10-15secs. It may take a few goes as there's a bit of a nack in getting the buttons pushed at the same time.
Let me know how you get on.
Jan 29, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Waste Ink Pads
ink waste is replaced br cleaning it through alcohols
Oct 26, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
EPSON 360
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Feb 19, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
3,450 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
