Question about Kenmore 62802 Electric Dryer
Dryer gets hot and tumbles, but load takes 2 hrs to dry complete.
  • Kenmore Master
  • 19,396 Answers
That means that there is a problem either with the vent , or the heating element, or the thermostat, rarely this can also be caused by a defective control.
Ususally this is a heating/thermostat, or a ventilation problem.
See also Drying is too slow.
Posted on Dec 18, 2008
How how long should it take to dry a load
Your problem is going to be 1 of 2 things either the dryer is not tumbling o you're not getting adequate air flo out of the drye which basically suffocates the drye which basically suffocates the dryer element preventing it from drying, you can check this by turning the dryer on and finding out where the vent is outside and verify airflow is good. My guess would be the second is the problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Aug 09, 2012 | Roper REX4634KQ Electric Dryer
The heater appears to be heating when drying but it takes 2 to 3 times to get a load dry? Thank you for the help. Scott Model 68712894
if your dryer feels hot inside and the drum tumbles then you have a blocked vent. check that the venting blows to the outside. do this test. unhook the vent behind the dryer, dry a load of clothing and if it dry on the first time then you know the house vent is clogged. cleaned or if you live in an appartment have maintenance clean.
Feb 12, 2011 | Kenmore Dryers
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer doesnt get hot anymore after 2 yrs
You may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you don't have any clogs. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back an let me know. I hope you find this information helpful.
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Clothes aren't drying properly
look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Nov 17, 2008 | Frigidaire Dryers
Kenmore 62802 Electric Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
