Question about Hayward H Series Propane Electronic Ignition Heater 150,000 Btu
My propane heater rumbles and thumps when turned on.
Its less noise when I turn the pump on to high speed.
  • 22 Answers
Sounds like you have a 2 speed pump. The heater needs high speed to operate. The noise is due to the low water flow. The water is actually boiling in the heater. Crank up the flow and that should solve your problems.
Posted on Dec 21, 2008
What might be experienced by transaxil/transmission bearings wear? Rumbling or vibrations?
Kia is bad with wheel bearings ;.About 80 to 100k they start going bad. You have to check them physically with a dial gauge or know how to inspect them in other manners. They cause a rumbling sound when they start to go bad.
Feb 01, 2015 | 2007 Kia Amanti Sedan
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
I have a starite propane heater i turn it on it calls for heat it will start heating then a couple minutes later the filtration lines and heater give a loud banging noise and service heater light comes on...
This is either one of two thing.
Either you pump is clogged, or failing and not providing adequate flow, or the heat exchanger has a hole in it. I would hope that it is just a flow issue as the exchangers are very expensive.
Check the pump first, and also make sure there is no leaking water from the heater
Nov 14, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Flame wont stay on, runs for about 5-10 secs and
usually the thermocouple wears out. Make sure the thermocouple is in the flame, if it is, and it still wont stay lit I would change that first.
Feb 28, 2010 | Mr. Heater MH175KT Open Flame Utility
Mr Heater MH12T noise and little difference in heat settings
HI Check out mr heater wed site there has been some recalls on some of there heaters if not take it back .............
Feb 09, 2010 | Mr. Heater MH9B Ceramic Utility
Raypack versa 20 year old propane heater used for hot tub pump has two speeds heater not turning on with low speed pressure turns on, but quickly cycles off then on and off repeatedly at high speed pump...
It is very hard to trll what is going on the way you describe it. It sounds like you have nothing at low speed on the pump but when you kick it up to high speed you get a cycling on and off of the heater.
You can try your pressure switch to see if it has a problem.
With the heater and pump off you will find the pre sw on your water manifold on the side of the heater. You will need to remove the side panels from the heater they are above and below the pipes coming into the heater. The pre sw will be a mushroom shaped piece that screws in to the manifold with two wires comeing out of it. It will take a small wrench (I think 7/16") unscrew this and make sure their is no rust or calcium build-up under it in the water chamber. If their is clear with a screw driver or the like and start the pump for a second to flush this out. (Careful or you will get wet) screw switch back in and run to check. If you find no problem here than it may be in the switch itself. If you bridg the sw with a jumper wire and it starts this is your problem, but you have to ck the other stuff first. Or you may be spending money on a pre sw for nothing. Do Not Just Jump Switch and Leave It At That!!!! This could ruin your heater at least or burn down your house. Of course if the filter, pump or pump baskets are dirty this will be the problem. But you say you checked those. Good luck and I hope this helped.
Nov 15, 2009 | Pool & Spa
The reset button comes on for laser 72
The thumping noise is the fuel pump starving for fuel. It sould like you are having a fuel problem. NO fuel, low fuel, dirty filter.
Tom Hawkins
hawkins111@gci.net
Jan 03, 2009 | Rinnai Toyostove Direct Vent Heater:...
Noise in right front end; 2001 Cadillac DeVillle
if its like a humming noise front wheel bearing has to be change most of time when you go straiht and turn the stering on one side noise less the other side more noise bearing noise go to a shop hopeit help fixya our post
thank you pierre
Jul 15, 2008 | 2000 Cadillac DeVille
Hayward H Series Propane Electronic Ignition Heater 150,000 Btu Logo
233 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
