Question about Nintendo DS Lite Console
Putting new shell on ds lite
I have a ds lite and have just bought a new shell to put on, bought the screwdriver to do it ,unscrewed the screws taken out the battery but cant seem to get it apart, i dont want to break it and be without,can anyone help?. i have asked the seller i bought the shell from and are waiting for them to get back to me
  • lesley_marie Dec 20, 2008
    i found a picture guide by guide, the guy that i bought the shell off gave me the website to find it .i took it apart but when i came to taking the cable(ribbon)that goes into the top half i stopped incase i broke it totally and then put it back together as good as i could,its a bit loose but still works. i will try and find a shop that does actually mend nintendos to do it (just in case it does break)then they could take the blame for breaking it. thanx anyway for the advice
  • sarahdunvill Apr 01, 2009
    i carnt seem to get the wires loose to detatch from the hindge
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
There out are plenty of DS and DS lite dissasembling guides with photos and even videos. I had posted some in previous problems so try searching here, if cant find here just use google.
Posted on Dec 20, 2008
  • Ed Perez
    Ed Perez Dec 20, 2008
    That is exactly the difficult part of changing shells, the top screen.
    But if you roll the ribbon well to get it through the metal ring then you are in your way. Some people use tape to avoid the ribbon from damage and keep it rolled. And some metal rings have a slot making it easier.
    But as your DS is not totaly broken then you have some extra time before doing it yourself. Anyway if you replace it you have a chance that the top screen ribbon dont get damaged, as it should happen if the hinges get totally out of place.
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Tip
DS Lite Dismantling Process, Ideal For Shell/ Housing/ Casing Replacement.
Has you DS lite devloped an issue that requires you to take it apart? Has your shell/ housing/ casing becomed damaged or is scratched? Have you broken the hinge and want to replace the relevant parts? This guide is for you.
N.B. - It is lengthly but thats because it is an indepth guide to make it suitable for even the most novice of people.
For this process you will need a few tools (all avaliable on ebay):
1) A precision cross-head "+" screwdriver.
2) A precision tri-wing screwdriver.
3) A pair of tweezers.
4) A craft knife or scalpel.
5) A flat-head "-" screwdriver or cutlery/ butter knife.
To begin you need to remove the battery, unscrew the battery compartment with the cross-head screwdriver and then lever it off with the knife. Next remove the battery by levering it out, you will see a small lip on the right hand side near the top, lever it up there. Now you need to remove the remaining 3 cross-head screws, their locations are:
1) Top right of the battery compartment.
2) Under the rubber foot next to the left shoulder button, lever the rubber foot off with the knife.
3) Under the rubber foot next to the right shoulder button, again lever the rubber foot off with the knife.
Screws 2 & 3 are of a gold colour whereas screw 1 is silver in colour.
Note there is another cross-head screw that is visible in the battery compartment, we will leave this one for now.
Next you need to remove the 4 tri-wing screws, these are located:
1) Top left of the base of the DS lite, just under the right shoulder button.
2) Bottom left of the DS lite, below the stylus slot.
3) Bottom right of the DS lite, its tucked right in the corner of the battery compartment.
4) This one is a little harder to see and a lot of people miss it... It's located at the top of the slot -1 port as you can see it is black and shorter than the others.
Now you can remove the back, gently pull it away from the top first and then lever it off at the bottom taking care not to lose the springs and rods found on the shoulder buttons. Take off the shoulder buttons and take a good look at how the springs are positioned as this is crutial to the performance of the button, take a photo of them if you have to.
To remove the motherboard you'll need to disconnect the wi-fi cable (black in colour) located on the wi-fi module (the extra piece of PCB* board attached to the motherboard) use tweezers to do so and then remove it from under the slot -1 component. Again using the tweezers, disconnect the microphone cable (white in colour) which is located on the motherboard directly diagonal to the top left corner of the wi-fi board, labled "p12".
Now remove the 2 screws holding the motherboard into place, they are located:
1) On the left hand side about 1inch above the headphone socket.
2) On the right hand side about 3/4inch above the volume switch.
Flip the motherboard up and over taking care not to put any strain on the top and bottom screen ribbons.
Disconnect the top screen by lifting the securing flap (if you have trouble use the knifes blunt side to lift it) and pull the ribbon away. Remember to put the flap back down after to avoid breaking it. This will now fully free the motherboard from the DS lite shell. If you need to, disconnect the bottom screen by again lifting the flap of the connector and pulling the ribbon free and then remove the touch screens ribbon using the same method, It's connection is located just above the wi-fi board. Remember to put the flap back down after to avoid breaking it.
If you need to replace the buttons or pads you can do so now, you will also see that you cannot put the buttons back in the wrong place because they are unique to their respective places. When replacing the pads make sure that the "black dots" are visable i.e. face up.
You will see 2 cross-head screws located at the top left of unit, if you unscrew them you can pull away the hinge which in-turn losens up the other hinge, but before you part the top from the bottom slip the top screens ribbon through the slot to release it and feed through the wi-fi and microphone cable. Now you can seperate the top from the bottom and if you need to, replace the hinge barrel and ring by pulling them away from the body of the DS lite and fitting the new ones in the reverse of the removal.
Now for the top half of the DS lite...
Firstly you need to remove the 4 cross-head screws, they are hidden under square, colour co-ordinated plugs and are located near each corner of the inside top half of the DS lite. To remove the plugs use the knife to lever them out but take great care as they are easily marked/damaged. Once the screws are removed you need to turn the unit over so that you can see the DS symbol and have the hinge side nearest to you. Place your thumbs on the top and your fingers on the bottom, now push away from you with your thumbs so that the top slides forward around 1/5th of an inch, you can now take the top off to reveal the insides.
Take note of how all the items are placed or take a photo if you need to. Firstly you can feed the top screen ribbon, wi-fi cable and mic cable through the hinge hole. The speakers are not stuck down and are held into place by the plastic housing so are easily lifted/ levered up. The wi-fi PCB* board is secured in much the same way and so removal is identical.
You need to loosen the screen in order to remove the microphone cable as it is held under the bottom of the screen, you will need to use a moderate amount of force to unstick the screen from the housing, use a flat-head screwdriver or cutlery/ butter knife to lever the screen out and away from the housing pull the microphone out of the housing either with tweezers or gently pulling on its cable.
Congratulations!!! you have now fully disassembled your DS lite! Give yourself a pat on the back.
To re-assemble the DS lite simply reverse the process. Tip- when putting the springs back make sure you put the end back into the slot so that it is taught and the shoulder button returns to its resting position after being pressed.
*PCB - Printed Circit Board
I hope that my guide has helped.
I take no responsability for any damage that may occur whislt following my guide, tips and tricks.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
Tip
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
Regards,
SOD69
Reboot nds
to reset the ds to factory settings, you will need a screwdriver. on the back of the ds is a little panel, just unscrew that, take the cover off and that that should reveal the battery pack. then all you need to do is take out the battery for a few seconds and stick it back in. put the cover back in and the next time you turn on the ds you will need to input all the data again as if you bought it for the first time.
May 17, 2009 | Nintendo DS Lite Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Which screws
precision screwdriver is a screwdriver with presion
Jun 11, 2008 | Nintendo DS Lite Console
Heyya
Please specify what the problem is so when you next put something on say what console and the problem, i cant seem to locate you from before, sorry for the inconvenience
Apr 09, 2008 | Nintendo DS Console
Looking for instructions
Does this help?
This site give a DS...and looks pretty much like the DS lite.
http://site.powergamingparts.com/RepairNDS.html
Good luck
Feb 14, 2008 | Nintendo DS Lite Console
Ds Lite
You may buy the screws here:
nintendo-ds-and-ds-lite-screws-and-springs
But my opinion is to go to a hardware store with a sample (cant be too long, the original ones are aprox 3mm long X 1mm diameter), try to find screws that fit and use normal philips screws instead these tri winding screws as you would need a tri winding screwdriver to put the original screws in place. All the screws in the NDSL screw in the plastic case except for the battery one that screw in a squared nut.
Good Luck...
Dec 16, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
129 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
