Question about Fuji FinePix A360 Digital Camera
HI I have fujifilm finepix F31fd camera and when I plug into my laptop with usb cord, computer does not recognise it.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Jan 04, 2013
5 Suggested Answers
SOURCE: I have FOCUS ERROR ON MY FUJIFILM FINEPIX s6500fd CAMERA
This is just a suggestion, as I am not an expert.A couple of years ago I had a problem with my older, Fuji Finepix camera related to the computer downloads/programming and I found Fujifinepix web site. I sent them an email and they responded and did not charge anything. Could try that..
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
SOURCE: cant upload photos to mac from s1500 fujifilm camera
In Spotlight, find Image Capture. This will recognize the camera and allow you to download the pictures off the camera.
Posted on Feb 28, 2010
  • 11967 Answers
SOURCE: Hi, I dropped my fujifilm
Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 08, 2010
How to download finepix 10 to computer
have you got the finepix installation disk ? or put the memory card into a usb card reader , your computer will recognise that
Oct 05, 2012 | FUJIFILM FinePix F10 Digital Camera
How do you transfer pictures from Fujifilm Z30 to Hp computer using USB cord? I searched this on another site but when I plug my cord in and turn on my camara nothting comes up and no pics. can be found in...
Connecting the camera to the computer requires that you install the software that came with the camera. If you didn't do that, you can still download your pics using a separate card reader. typrice_217.jpg
Jul 18, 2011 | FUJIFILM FinePix Z30 Digital Camera
How do i transfer photos onto my computer ?
you would be having a data cable provided with the camera... plug it in to the camera as well as the computer USB port. install the camera drivers (generally not needed) and you system would recognise the camera, after this you can transfer the images from the camera to the computer.
Mar 12, 2011 | FUJIFILM FinePix J40 Digital Camera
Print FinePix F31fd INSTRUCTIONS
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Aug 04, 2010 | Fuji Finepix F31FD Digital Camera
Isn't recognised on computer
Get the drivers installed from below link:
http://www.fujifilm.com/support/digital_cameras/software/usb/index.html
After installing the drivers, you need to plug the camera again.
Jun 27, 2010 | Fuji FinePix S3500 Digital Camera
F31fd webcam on windows 7
http://www.fujifilm.com/support/digital_cameras/software/finepix_viewer/ver55win/download.html
Oct 03, 2017 | Fuji Finepix F31FD Digital Camera
Cant upload photos to mac from s1500 fujifilm camera
Jan 04, 2010 | Cameras
I can't get my pics off my camera on to my PC.
Try the XP USB driver from Fuji here:
http://www2.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-m603-zoom/support
Mar 10, 2008 | Cameras
Fuji FinePix A360 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
