Question about Dishwashers
Hot point dishwasher washing in cold, have replaced heating element no change . can you help
  • paulchard511 Dec 18, 2008
    hi, checked with hotpoint and they said the thermostat is built in with the heating element as these are both now new it can,t be these. thank you
  • 19,396 Answers
Check the thermostat and eventually replaced, if it is not the thermostat , then it is a defective cycler/timer control assembly.
If your dishwasher has also hot water power supply, try also increasing incoming hot water temperature.
You can find machine diagrams by entering model number here.
Posted on Dec 18, 2008
There's only one pipe for water is it a cold water dishwasher or hot model number adp755
If there is only a single water inlet then it has to be connected to the cold water connection. Generally dishwashers use internal heater elements to heat the water during relevant wash and rinse cycles.
Hope this helps.
Jan 02, 2013 | Whirlpool Dishwashers
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
Water not hot enough. Supply water is plenty hot but washing water is not hot.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 12, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
On model du81qdwgq1 is hot or cold connection
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher issues
You should always turn the hot water faucet at the kitchen sink first before starting dishwasher. If you don't your entire wash is cold water. This will also cause the water temp mode to take forever to heat the water to the 140 that is factory set. Hope this helps.
Feb 02, 2010 | Dishwashers
No hot water
Hi Jon, is this a new machine that you have just got? if so it sounds like the hot and cold water pipes are on the wrong way round. If not sounds like a thermostat problem
May 29, 2009 | Whirlpool 24 in. ADG7540 Built-in...
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
GE Dishwasher SSD3900J00ww wash water cool heating element hot on
Crew that installed new cabinets and sink hooked dishwasher to cold water line I switch it works fine now. Thanks Don
Mar 20, 2009 | GE Dishwashers
Indesit DG6100W problem...please help!
Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
Hope you get it fixed.
Jul 01, 2008 | Dishwashers
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
