Question about Fossil BQ9165 Wrist Watch
Can't get the back on.....
I changed the battery on my watch, and now for some reason I cannot for the life of me get the back cover back on my watch, any tips?
  • 2334 Answers
SOURCE: Cannot get the cover back on Fossil watch after changing battery
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Posted on Dec 21, 2008
0 characters
1 Points
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Oct 23, 2013 | Seiko Coutura Chronograph Watch
How do you change a watch battery
Pretty sure you just pop off the back, take out the old battery and put in a new one. Stores that sold watch batteries use to do it for you, some don't now. Liability reasons they say.
Mar 11, 2012 | Watches
I need to change the battery of my watch and i don't find the place for removing the back cover
some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
Aug 15, 2011 | Callaway CY2058 Sport Series Watch
Have had a ***** watch for my birthday strap has broken after a week!! where can i get a replacement
You should take it back to the supplier.
I know that the guarntees do not cover the strap but it is reasonable to expect a much longer life than this! The strap was "not suitable for purpose".
You should get a replacement free of charge.
Aug 02, 2011 | Calvin Klein K9322102 Mound Wrist Watch...
Needs batteries lionel collectable train watch need user guide and battery size
The Lionel Collectable Train Watch has 3 batteries in it. Two are for the whistle and one for the watch. All of them are V377 or 377 disk batteries. Gently pop off the back cover as most watches come off the same way. The battery by itself toward the middle is the train timepiece watch battery and is installed with the + side up toward you. The two batteries toward the edge are the whistle batteries, and you have to be very careful in changing them. Thee us a rotating contact that is plastic coated, over the batteries. NOTE: THE BATTERIES ARE NOT BOTH IN THE SAME DIRECTION. ONE IS UP AND ONE IS DOWN. (LOOK VERY CAREFULLY FOR A + AND - SIGN ON RIGHT NEXT TO EACH BATTERY.) For this reason, it is recommended to only change ONE battery at a time, so you will not get them mixed up. Gently spin the contact one direction, and one of the batteries will be clear and come out. Change that battery. Now rotate the contact back to the original position over both batteries, and continue rotating in that direction until the second battery is clear and can be removed. Change that battery. Now you can confirm that you still have one battery up and one down. Rotate the contact back to its original position, centering it on each battery. This contact has a layer of plastic material covering it on top so that it will not contact the watch case. If this plastic coating is damaged, it can damage the watch. If it is damaged, you might put a small piece of tape over the contact, to prevent other damage. NOTE that close to the edge of the watch is a very, very small spring sticking up. Make sure that spring is still vertical, as it is very delicate and can be damaged easily. That spring as well as the metal arm sticking up are part of the speaker circuit and must be in their place when the cover is replaced, as the speaker is in the cover. Now gently replace the cover until it snaps down. You will see the train moving around the dial and you can push the button and hear the whistle. Incorrect changing of these batteries by persons in jewelers departments of stores like Walmart and Target, have damaged more of these watches than you would like to believe. Hope this helps. (By the way, I do not have a brochure for the watch at this time.)
May 27, 2011 | Watches
How can get sound on my iroman 8 lap watch after changing battery. I wander if there should be a tape in the back cover and if yes to what extent it should cover. when I set my alam I see the fainting of...
mcdevito75 here, It"s possible the NEW battery in your watch is weak from an extended shelf life, I'd return to the place the battery was installed and ask. Also you can go over your watches functions again as the watch has to be re-set once the battery is changed.
Jul 15, 2010 | Timex Watches
1 Answer watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Sep 25, 2009 | Swatch Irony Chrono Unisex Watch #YMS400G
Screen stuck on battery life indicator
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Sep 20, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
How can i remove back cover of mens reaction
As a certified watch repair tech. I would not recomend changing your own battery. If you can get the back off there is a big chance that you will have difficulty getting the back back on. These watches are meant to be water resistance up to whatever level. When the case is open the seal is broken and needs to be either replaced or silicone needs to be added. This insures that your watch stays water reisitant and now that it is sealed the battery can have a longer life expectancy.
Jun 28, 2009 | Kenneth Cole KC1104 Wrist Watch
Fossil BQ9165 Wrist Watch Logo
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
