Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
20 Hp (kawasaki) John Deere GX255 tractor over revs when cold.
I live in the midwest and use my tractor for plowing snow and when it gets around 15 degrees or colder the engine runs continuously at very high RPM from ignition on to shut off. The throttle control seems to be moving ok but has no effect at all on the RPM. It will slow a little when under load but still well above normal weather RPM. I have yet to tear into it but my first inclination is a sticky governor. A friend suggested adding a little isopropol to the fuel. Which I did but the whether has since gone up to where it runs normal. Because its an intermittent problem it would be helpful to get some opinons about where to look for the problem because I will be working on it in a garage where it will be warm enough to not experience the problem. Any help would be greatly appreciated.
  • 43 Answers
The engine is icing up. Kawasaki may have a winter kit available. I have solved the problem it the past on other engines by partial blocking the air intake screen with cardboard. Cut a piece of heavy card board the same size as the intake screen cut a few pizza slice shapes out and zip tie it to screen. remove in the spring. refer to owners manual if you are unsure what the air intake screen is.
Posted on Dec 19, 2008
I have a John Deere hydro 165, Kawasaki 12.5 ,what oil does it use?
Most all Engines used in warm climate such as mowers etc.. Use standard weight SAE 30 but colder climates machines such as snow blowers etc. use any good quality mili viscosity oils 10-30 is an all around one..good luck a little higher such as 10-40 for high hours used machines..good luck..
Aug 25, 2015 | John Deere Garden
How to install. A snow plow and ordering a couple of parts for it
From the part numbers you post I gather it is a John Deere equipment and your local JD dealer will be your best bet getting instructions and parts for that snow plow.
Jan 01, 2015 | Garden
How to check problem with john deere 200d lc cooling motor stoped moving
if i understand you right your saying the cooling fan doesnt work at all , yes it's run by a electric motor , it's triggered by the ECM via a control relay /fuse that gets a cool /notcool signal from engine coolant sensor any of these not working correct will produce the effect u see, normaly this will make the fan ,Modulate (off/on) for diff enviroments like mine doesnt even run when plowing snow but runs all the time plowing a field , due to diff time of year
Dec 15, 2014 | John Deere Garden
Why does it idle up & down constantly
which v-twin ???
Kawasaki or Briggs or Kohler
but I'd suspect a dirty carb just by your question
Aug 30, 2014 | John Deere Garden
How to make JD GX255 to mow in reverse?
Have you tried you to disconnect it ?
Jun 11, 2013 | Garden
I have a John Deere GX255 Garden Tractor with a 20 HP Kawasaki engine. The engine sputters like it is running out of gas but never dies. I have changed the fuel and air filters and replaced the gas but it...
its over due for a valve adjustment its not to hard try cleaning your carb out if that dont fix it let me know and ill tell you how to do the valves
Oct 04, 2009 | Garden
John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
Mar 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
289 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
