Question about Toshiba Satellite A100-S8111TD Notebook
No power going into the laptop
I have a toshiba satellite a100-332 and i have just brought a new power lead for it so i no its not the lead, when i plug the laptop into the mains no power is going into the computer is this a major problem and anybody know how to fix it
  • intelligent1 Jan 06, 2009
    I was working in excel this morning... the computer had been plugged in all night, so the battery was fully charged, and was plugged in at the time of use, then all of a sudden the whole computer went dead... didn't even go through the usual shut down cycle. None of the indicator lights were on or anything as they usually would be when plugged in, and the battery wasn't even powering it. I tried unplugging the cord from the machine and removing and replacing the battery (same one) and now when I press the power button the battery indicator light flashes about 12 times, but nothing else happens. I plugged the cord bac into the machine and still nothing..?? huh? In the meantime I'll keep trying different things.. Thanx.
    Scholar:
  • 86 Answers
Hi
A fault I frequently come across is the power socket either breaking up, breaking out of the motherboard or more often now just an array of dry joints causing all sorts of odd problems. Build quality of laptops is rubbish these days - they have to cut costs to save money because of the lower overall price of laptops
Posted on Dec 18, 2008
Loose power connection on motherboard of Satellite L640D-ST2N01
Toshiba Satellite laptops often have problems with their power connections becoming loose and losing contact between the positive pin on the DC power jack and the motherboard. Laptops are not designed to operate on the battery when the AC adapter is plugged into a viable power outlet. You will have to disassemble your Toshiba Satellite laptop to repair this problem. This task requires a thorough knowledge of laptop repair and safe soldering practices.
1. Disassemble your laptop according to the instructions for your specific Toshiba Satellite laptop model. Cut the plastic supports off the base assembly with a knife.
2. Cut off the plastic wall that encircles the mount opening with the knife. Extend the circumference of the hole by carving it open with the knife to make it wide enough for the new jack.
3. Bring the ends on the negative lead for the jack together and cover the ends with solder.
4. Remove the original DC power jack and trim the wires from the jack box with the knife, until they sit close to the edge of the jack box. Use the knife to strip the wires. Use your fingers to twist the wires together, and then coat the point where they meet with fresh solder. Locate the positive wire -- it is either red or green. Plug this wire into the positive lead on the new jack, and then find the negative black wire and attach it to the negative lead on the new jack.
5. Place the new power jack in the base, keeping enough extra space available for the plastic laptop cover and right speaker to fit back in later. Cover the negative and positive leads with the electrical tape, and then manually rotate the nut on the power jack clockwise until it will go no further.
6. Figure out which walls will stand in the way of the power jack after you secure the plastic laptop cover. Cut these walls out with the knife. Reverse the disassembling instructions you followed previously to put your laptop back together.
Dec 01, 2013 | Lifetime Toshiba Satellite L640DST2N01...
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
I brought a new toshiba satellite pro L450/L450D laptop but i couldnt open it, it needs password...which i dont know somebody help me please???
Return it to the store and let them fix or exchange. Sounds like it was a demo unit that they set a password on.
Aug 05, 2010 | Toshiba Satellite Pro L450 Notebook
Toshiba satellite P205-S6287 the power button
Make sure the battery has a full charge, and that it's plugged into a wall socket, then try the power button. You will get the same symptoms as a bad power switch if your battery power is very low. Other than that, the battery could be bad, or going bad. If the problem is a faulty power switch, you will have to have it replaced.
Mar 12, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Hi, I have Toshiba Satellite (Fusion Finish) A305-S6858 special edition which my uncle brought for me from the US lasy year. But the picture quality is genrally poor. How can I correct that?
You have not installed Graphics/Video drivers on your laptop. Go to toshiba website and try downloading the drivers, or go to www.intel.com if your system is intel processor.
Regards
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Satellite U205 power adapter damaged and needs replaced
TAKE YOUR OLD ONE WITH YOU GO TO RADIO SHACK OR FRYS ELECTRONICS, BEST BUY, COMPUSA, SOME LARGE COMPUTER WAREHOUSE TYPE SHOP AND THEY SHOULD BE ABLE TO CROSS REFERANCE A COMPATABLE UNIT, GO ON EBAY.
ROD
Feb 09, 2009 | Toshiba Satellite U205 Notebook
Toshiba Satellite A135 won't power up
Computer was outside (cold) out of the briefcase for a period and found that when it was brought inside it created some condensation. 30 minutes with a hair dryer on low dried everything out nicely. Computer started right up.
Dec 13, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba won't start
Hi, what happens when you push the button? Lights, sounds from inside the laptop, anything flash on the screen?
Sep 27, 2007 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
