Question about Brother MFC 7420 All-In-One Laser Printer
After reinstalling it wont scan or send faxes, the error comming up is error initializing in control center2. lack of registrer information. Install once again MFL-pro suite please help thanks C.
  • bekra Jan 13, 2009
    Hello Crespec,
    I all ready did that, but it didnt work
    Thank you any way
  • 320 Answers
Ununstall the brother software that came with the machine, then reinstall the cd brother mfpro sofwar, if you are still having a problem, let me know. brother tech
Posted on Jan 13, 2009
  • STEVE RAYMOND Jan 13, 2009
    after checking with tech support the main pcb might be bad. if the machine is 1 year or less, you will still have the warranty,other wise you will have to take it in for service
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Unable to Scan
Remove the TWAIN software and reinstall it. Best if you can use the add/remove software in the control panel. You might want to look in the Device Manager for the USB entry that controls the device and remove that. If you find it open with an error, definitely remove that entry.
You might want to check with Brother to see if they have a updated driver for your 5840.
Thanks for your question at
Jan 01, 2010 | Brother MFC-5840CN All-In-One InkJet...
I cant scan a document in my computer
During a normal installation of the HP All-in-One software, the following events occur:
1. The HP All-in-One software CD-ROM runs automatically.
2. The software installs.
3. Files are copied to your computer.
4. You are requested to connect the HP All-in-One to your computer.
5. A green OK and check mark appear on an installation wizard screen.
6. You are requested to restart your computer.
7. The Fax Setup Wizard (Windows) or Fax Setup Utility (Mac) runs.
8. The registration process runs.
If any of these things did not occur, there is most likely to be a problem with the installation. If the essential icons (Scan Picture, Scan Document, and Send a Fax) do not appear, your installation might not be complete.
If your installation is incomplete, you will need to uninstall and then reinstall the software. Do not simply delete the HP All-in-One program files from your hard drive. Make sure to remove them properly using the uninstall utility
provided in the HP All-in-One program group.
Sep 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
Control Center2 will not start - Error cc025
Had the same problem. The solution was: - uninstall the brother software with the application in the brother folder restart PC - reinstall mfl-pro Suite restart pc - install update to Controlcenter2 - install updated drivers
It then worked and I could finally scan over the network, for the first time ever!
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
"Broken Registration"
U need to press "STOP" to return to idle state.
If this Error Message is repeatedly displayed, machine programming
has become corrupted.The machine must be re-initialized.
Pressing *13 and ON the machine, it will re-initialized the fax.
Jan 03, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
When sending faxes, error pages always follows fax
go into menu -initial setup- look for the option that says tx report or com journal and set that to incomplete only or off, sounds like it is set to always. if the setting is not in the menu i mentioned keep scrolling through youll find it
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Error Message: Scan Unable A6
did you get the solution to the problem u mentioned
Feb 21, 2008 | Brother MFC-8220 Fax
HP L7680 All in one will not send faxes from PC S/W interface
After much thrashing, here is the solution to the problem. Somehow the printer drivers lost coordination with the corresponding Windows supporting programs. You would think that reinstalling the printer drivers would fix the problem, AND IT DOES, but there are 3 tricks:
· Uninstall everything associated with this printer with the install disk in the computer (this may really not be necessary, but it worked for me). [This is also the solution when the a window comes up asking for TrayApp to be inserted using a disk—they mean the hp install disk].
· After the un-install, MAKE SURE you ALSO delete the printer using the control panel. This is critical. If this doesn’t happen, the corresponding Windows software is somehow hooked to the wrong thing when the reinstall happens. Then reboot the system.
· Install the new drivers with the printer off, and the USB disconnected from the printer. Reboot the system [not sure the reboot is necessary]. After the computer has booted, connect the USB, and power up the printer. The computer will recognize the printer and put the printer icon in the Control Panel.
It turns out that correcting the driver mis-coordination by BOTH uninstalling the printer drivers and taking the printer out of the control panel, then properly reinstalling solves BOTH the fax problem, and the protection fault problem! Amazing such a little thing can make such a difference!
Jan 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC 7420 All-In-One Laser Printer Logo
94 people viewed this question
James Cagle
James Cagle
Jim Keysor
