Question about Hotpoint Ultima WF860 Front Load Washer
My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you
  • Hotpoint Master
  • 3,463 Answers
Hi.
F12 indicates 2 or 3 differant faults.
Try these first.
Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
Select a drain prog, and see if it pumps out o/k.
If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
Plz rate my solution .Thanks.
Posted on Dec 22, 2008
My door is shut and light is on flashing door on my hotpoint washing machine WT741. the door is shut and it does lock aswel so why the flashing light and no washing being done?
There is likely to be a problem with the 'door closed' sensor/microswitch requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 07, 2011 | Hotpoint Aquarius WD63 Front Load...
My Hotpoint Ultima WT741 is stuck in test mode. Can anyone tell me how to cancel. Carol
unplug for 40 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 19, 2009 | Washing Machines
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
176 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
