Question about Intel Desktop Board D850MV (KD850MVPAK10) Motherboard
3d error show while running most of modern games/ AGP upgradation
P4- 1.7 GHz - 512Mb RDRAM - Nvidia TNT2 (64) installed.
Most of the new games do not run because of older AGP card/ non availability of 3D graphics card. Please suggest suitable AGP/VGA so that game of size 1 or 2 GB can be played.
    Genius:
  • 1,019 Answers
It takes a hell of a computer to run decent games.
My suggestion would be to save your money, to invest in a new computer setup.
if you get a quality graphics card, for example NVidea geforce 8600 or 8800gts et,c.
your system, will not have the Memory, so you,ll then be spending on RAM.
Next step will be that, your CPU isn,t powerful enough, so that,ll be upgraded. And it,s probably already at maximum or thereabouts, for the motherboard.
I always say, if you want to play good games, get a games console.
It,s much cheaper and cost effective, you can spend £700+ to get a computer to play a game, that an xbox 360 will do for £130. Think before you spend.
Regards mike @ compurepair.
Posted on Dec 18, 2008
I cant play modern warfare on my graphics card is there anything higher than this that can play those games for agp
I kinow of a 512mb geforce card but most high end cards these days are using pci-express. If you really want to continue with modern games, it may be time to upgrade your pc.
Sep 05, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
What cheap but good video card should i get to run modern warfare 2 on my dell desktop computer
From what I can determine, for you to have the permornace you need for Modern Warfare 2, the following are the recommended computer requirements:
A CPU: 2.4 GHz dual core or better, RAM: 1 GB on XP / 2 GB on Vista and Windows 7 and a
GeForce 9500 GT 1GB memory Graphics board. (this is a PCI Express slot board).
Make sure your Dell has the slot required for the graphics board, if no slot then there is an AGP board, but with 512MB memory that would work good.
Either graphice baord would cost about them same
Recommend, EVGA @ Negeeg.com or Tiger Direct.
Good Luck
Sep 04, 2011 | Nvidia GeForce FX 5500 256 MB, (256 MB)...
I want to upgrade my cpu for this mother board from 1.8 ghz to 2.8 ghz. What cpu should I go with. Am I going to run into problems with the bios or anything else. Also need to know if I can upgrade...
Here is a link for your mobo
http://www.asrock.com/MB/overview.asp?Model=P4VM800
looks like you can use any intel processor as long as its a socket478 by intel
Check out nvidia agp cards at www.nvidia.com You can get a 512mb card agp.
The bios is plug and play which should not be a problem.
You may need to upgrade the memory also.
Mar 22, 2011 | Asrock P4VM800 Motherboard
Looking for best agp for dell gx260
hi
yes you can up-date and it will support 512mb go to folowing link you will get your solution
http://compreviews.about.com/b/2008/03/12/best-agp-graphics-card.htm
May 26, 2010 | Dell OptiPlex GX260 PC Desktop
7600gs agp problem
try turning off the on board vid
Jun 30, 2009 | E-Machines T4480 PC Desktop
Nvidia 6200 agp will not play games on s video
What Monitor settings are u using? Try higher frequency & if its a 17" monitor use 1024 x768 setting(resolution) and frequency 75-80 Hz. Also check the nVidia website for driver update for this model. I recently saw that there is a new driver in this category!!!!........sodeep
Mar 24, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Nvidia G-Force FX5200 256RAM
The following was taken from http://www.busdrivergame.com/support.php#14 Based on the below description, I believe your problem would be solved by updating your video card drivers. The ones that ship with the card on cd are always very old. Here is a link to get the new drivers from NVIDIA. You did not say, so I will assume you have Windows XP, if so, here is the link for the most recent driver: http://www.nvidia.com/object/winxp_175.19_whql.html If you do not have XP, then go to this link and find one for you OS http://www.nvidia.com/Download/index.aspx?lang=en-us If this works, I would appreciate a rating, I am new to fixya and would like to get a good rating. Thanks and Good Luck!! 14. I get a message saying: We are sorry, but the operating system failed to provide the window to render game graphics in. Bus Driver immediately crashes with a Prism3D error. There are several possible causes for this to happen. In most cases, the critical element of resolving the problem is upgrading video card drivers. (See #8 above)
  • Reportedly, some computer vendors ship new machines with the system preconfigured, but without proper drivers for the particular brand of 3D accelerator card installed, including OpenGL support. Make sure to always have proper up to date 3D card drivers installed.
  • Upgrades of certain Windows components (upgrade of DirectX, a Service Pack application) may require driver reinstallation afterwards.
  • You may have your desktop color depth (Color quality) in Windows set to 256 colors. Make sure you have Windows running in 16-bit or 32-bit color depth.
  • You may be using a very old computer with hardware capabilities below minimum specifications required to run Bus Driver.
Dec 14, 2008 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Nov 21, 2008 | Gigabyte GA-8ST800 Motherboard
Program won't run, error message says it can't find 3d software.
If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
Recommended System Requirements:
- 3 GHz Intel Pentium 4 or equivalent processor
- 1GB System Ram
- ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
1.2. Minimum System Requirements
Minimum System Requirements:
- Windows XP
- 512MB System RAM
- 2 GHz Intel Pentium 4 or equivalent processor
- 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
- CD-ROM or DVD-ROM drive
- 4.6GB free hard disk space
- DirectX 9.0c (included)
- DirectX 8.1 compatible sound card
- Microsoft .NET 2.0 Framework for toolset (included)
- Broadband connection for multiplayer online play
- Keyboard, Mouse
1.3. Supported Video Cards
- ATI Radeon X1900 series
- ATI Radeon X1800 series
- ATI Radeon X1600 series
- ATI Radeon X1300 series
- ATI Radeon X850 series
- ATI Radeon X700 series
- ATI Radeon X600 series
- ATI Radeon X300 series
- ATI Radeon 9800 series
- ATI Radeon 9600 series
- ATI Radeon 9500 series
- NVIDIA GeForce 7900 series
- NVIDIA GeForce 7800 series
- NVIDIA GeForce 7600 series
- NVIDIA GeForce 7300 series
- NVIDIA GeForce 6800 series
- NVIDIA GeForce 6600 series
- NVIDIA GeForce 6500 series
- NVIDIA GeForce 6200 series
- NVIDIA GeForce 6100 series
- NVIDIA GeForce FX 5900 series
- NVIDIA GeForce FX 5700 series
- NVIDIA GeForce FX 5600 series
- NVIDIA GeForce FX 5500 series
Oct 28, 2008 | Video Game Consoles & Games
Problem playing certain games
driver wont matter buddie that mx 400 aint made for games ok upgrad eyour card to nicer one to play alot new games what kinda slot u have pci or agp
Jan 07, 2008 | Gateway GeForce2 MX400, (64 MB) AGP...
Intel Desktop Board D850MV (KD850MVPAK10) Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
