Question about Acer TravelMate C110 Tablet PC
Can`t find the cmos battery ML2032 RECHARGABLE 3V in the shop
Whrer can i find it?
Have you been able to get a replacement by now? If not, you can get them from budget batteries, www.budgetbatteries.co.uk. Just lift up the plastic under the battery and you should see the CMOS one . Un-solder the old one and solder on the new. Easy!
Posted on Aug 13, 2009
  • 431 Answers
Hi I am Vortash this battery is usually accessable from under the keyboard on most computers.. however some have their own access door under the computer , and I have seen a couple behind the Ram module under neath them in fact .... hope this helps Regards Vortash
Posted on May 19, 2009
My tablet does not charge
If the power supply is OK,then clean inlet of tab and jack of supply. Make sure the tab is powered off and the battery is not connected.
Oct 09, 2014 | ARNOVA 8 G2 Wireless PC Tablet - 8 GB USB...
Every time I turn it on, I have to reset all setting, It will not save setting after it is turned off. I.E clock, and date: some times wireless settings depending on how long it was off. Cmos batterie?
YES. The CMOS battery (complementary metal-oxide semiconductor) is low off charge or dead and needs to be replaced.
The CMOS typically is a battery-powered memory chip in your device that saves information needed at start up (before any software or program will run). If the battery is low of charge or is dead, you will eventually lose your personal settings and even some factory settings. The CMOS battery can be discharged if you have not used your device for long time.
Hope this helps.
Jun 25, 2011 | Sharper Image Literati Reader 16375680042...
I replaced my Toshiba Tecra M4 tablet CMOS battery and I am still getting the error why is this and how do I fix it? I cant get passed the CMOS error when I boot the computer.
When you replace the CMOS battery, you must wait about 10 minutes with the old battery removed, before fitting the new one (if you had a problem with the error message before) - when you fit the new battery, plug the tablet in and don't turn it on - this will give the new battery a chance to power up all of the CMOS on the board and settle down. Then turn it on, wait for the error message about the date and time being wrong, set the time correctly and the problem has gone.
Jan 02, 2011 | Toshiba Tecra M4-S435 Tablet PC
Ok I taught I had fought this battle and won but still no video even after replacing CMOS battery and the additonal small battery pack. I carefully made sure everything was correctly plugged in exactly as...
who told you that the fault was from the Cmos battery? This is a display issue and not cmos battery. Who ever told you it was a cmos battery problem was wrong. The function of the cmos battery does not concern video problem.
Since the fault has to do with video, you will have to check the screen and screen inverter.
Also, does you tablet PC has a space for any external display like motherboard? You can connect it to an external display to see if there will be a display. ( This is optional, if it does not have external display connector, then you cannot do this).
So review the inverter because there is every possibility that the fault is from there.
I hope this makes sense to you.
Good luck.
Jul 02, 2010 | Fujitsu Siemens Stylistic ST4120 Tablet PC
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
Howto reset cmos on toshiba 3500. I can remove the cmos battery, but have no info on wher any cmos jumper may be. Can't see it on the board.
You can just use a paper clip (straighten to a U shape) and short out the battery contacts.
If you are not sure, just leave the battery out for 20+ mins then put the battery back in the holder.
The BIOS settings will then be set back to th default settings, then go into the BIOS setting and set the Date and Time etc.
Jan 29, 2010 | Toshiba Portege 3500 Tablet PC
How to change cmos battery?
the COMS battery is part of the motherboard, in most PCs they are inserted in a removable slot, the battery is a watch cell the size of a Dime and can be replaced (the battery serial/model # may be CR2032)
In some they are fixed in the motherboard, it's hard to remove it in this case.
u need to open the PC box to look for the battery, it can be easily detected if you can view ur complete motherboard.
Jan 21, 2010 | Fujitsu Stylistic ST5112 Tablet PC
How do i change the cmos battery in a travelmate c110. The time and date and bios settings keep changing. Figure it needs a cmos battery. thanks
The cmos battery is exactly located beneath in between the touchpad and speaker, it's a meticulous job, you could see a twin cable leading through the keyboard area. After removing the keyboard, cut the battery wires at the edge of the old battery and replace the new sealed pack by soldering its wires to the same connection. Be cautioned not to break off the slim edges of the keyboard sides by attempting to reach the battery while lifting up top silver panel from the front near the Infrared.
Nov 12, 2009 | Acer TravelMate C110 Tablet PC
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
Cmos battery for C110 TCI
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Apr 27, 2008 | Acer TravelMate C110 Tablet PC
Acer TravelMate C110 Tablet PC Logo
710 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
