Question about Bulova Watch
I need instructions for my Stuart watch
I bought this watch from Stuart several years ago but misplaced the instructions. It is an automatic wind with 4 dials on the front, day, month date of month and one that has 5ATM with the moon cycle. On the rear are the numbers 11575 plus 5ATM.
Thank You
Richard Habicht
410-574-2886
  • 10,515 Answers
The link for the instructions guide :-
http://www.bulova.com/service/instructions.aspx
Thanx.............................
Posted on Dec 18, 2008
    Genius:
  • 1,061 Answers
Yes sir go here and download it.Not sure if its the right watch?contact support or call.RICHARDM69
  • 495 Answers
Go to this site:
www.bulova.com/dynamic_repository/instructions/570.pdf
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
Jun 03, 2011 | Orient CEUAA002WW Wrist Watch
Does the Diesel Mens DZ9015 watch have a battery. This is suppose to be an automatic winding movement watch. We have the original manual but only says to wind it and gently swing side to side. We tried...
Automatic watches are spring driven and have no battery.
Swinging gently from side to side will wind it up but you need to do this for some time (some makers say 200-300 times).
If you do this and it still does not work, then cleaning might solve your problem. (It did with one I had some years ago).
May 05, 2011 | Diesel DZ9015 Watch for Men
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
Bought a 1970s tissot automatic seastar watch and was ticking for two days the just stopped. Have tried winding but won't work. What is most likely the problem?
A self winding watch will run for 2-3 days if it is not worn (they thrive on being used) and it sounds as if you have not been using it; is this the case?
It could be that the winder does not operate on the spring (some watches don't), so to wind it up you need to activate the self winding mechanism.
You can do this by gently swinging the watch from side to side for a few minutes. This will simulate the normal operation when it is being worn.
If you continue to have trouble with it stopping, it could be that it needs cleaning. I had a similar problem with a watch I had some years ago.
Jan 18, 2011 | Tissot T Classic Seastar II T55.8.283.11...
I bought a new watch today and i cant get it to run
Watches fall into two basic categories - quartz and mechanical. If you bought a quartz watch that is battery powered you need to set the watch and push the crown in all the way to start the watch. Sometimes you need to remove a small plastic piece from the stem to push it in all the way. If you bought a mechanical watch, even if it is an automatic self-winding model, you will need to manually wind it to get it started. If you are still having problems take it back tot he dealer for a demonstration or to have the battery replaced if required. An instruction sheet and warranty card is packaged with almost all new watches. Sorry I can't be more specific but if you care to share the make and model number I may be able to help you further.
May 01, 2010 | Watches
I bought this watch citizen BL5334-04E year ago,
Mechanically operated date changes occur at 12 O'clock. If your watch thinks it is midnight when it is noon then it will change date.
The solution is to wind your watch on 12 hours.
Apr 17, 2010 | Citizen Eco Drive Perpetual Calendar...
Day/Date change
The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
Apr 10, 2010 | Guess Dress Bracelet 87000L1 Watch for...
I have a etica watch au9101 I don't know how to set the month and if it takes a battery when i got the only thing I got was a 5 year warranty card with ( no owner manual) Thank you
As I can see from the picture here:http://www.etica.ch/banner/AU9101.jpg your watch do not need a battery as it is automatic/selfwinding mechanical watch. There are two push buttons on the side. One of them is for month setting and another one for day setting. Use small pin or ball point pen to push them. Try both and you will see which one is for the month and which for the day setting. Push repeatedly until the desired month and day is set. Date in small window can be set by winding crown. Pull out crown half way out and set the date, then pull out crown further out to the time setting position and set the correct time. Push the crown back in and wind it back and forth at least 15 times to start the watch going. Before you start any of adjustments, set the time to 5.30 (am or pm - doesn't matter). It will prevent accidental damage of day/date/month mechanism. Rate me, plz.
Feb 28, 2010 | Watches
Bulova Watch Logo
63 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
