Question about Sony STR-GX900ES Receiver
Sony STR-GX9ES We have a Sony STR-GX9ES. However, the FM channel range only goes from 76 to 90. Any suggestions how we can get the entire range of FM stations?
5 Suggested Answers
mlapres
  • 757 Answers
SOURCE: My Sony STR-DG600 Receiver constantly goes into Protect Mode when using FM or XM.
Check to see if the antenna is firmly connected and not making contact with the receiver chassis or other inputs/outputs.
Posted on May 09, 2009
videotransmi
  • 105 Answers
SOURCE: when iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Posted on Jul 09, 2009
  • 4234 Answers
SOURCE: i have a sony str-de335 fm stereo receiver and
This can be shorted output transistors (common) or a defective voltage amplifier IC. WIthout taking measurements inside, there is no way for me to make that determination. In any case, this should be a relatively simple repair for a shop that repairs audio gear. Expect a parts cost in the $25-$40 range.
Dan
Posted on Aug 19, 2009
palaboy
  • 5807 Answers
SOURCE: Sony STR-DE197 AM-FM Receiver. Has
Inside the Receiver there are electronic components mounted on the aluminum
heatsink ( Audio Output Power Transistors )
it may looks like these :
MN2488 ( Q753 )
and usually paired with MP1620 ( Q754 )
You may have to check on those two pairs of power transistors
and replace in pairs.
( which means if any of the two is bad , have them both replaced )
Check also the audio signal on the right channel input , if it
is on the same level of those of the left channel.
These components are available at:
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-/MN2488
Posted on Feb 22, 2011
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
Dec 18, 2014 | Sony 7.2 Channel 4K Black A/V Receiver -...
My str de 925 will no lock on a radio station
Insure that the antenna is connected securely on their respective antenna
input, Stations will not lock , if the signal is low.
For FM :
• Wire antenna is applicable if your distance to the nearest FM
is about a km or less, other wise use a VHF TV antenna.
for AM :
• These antenna is directional, you may need to extend the wires
so as to receive AM stations.
Jul 31, 2012 | Sony STR-DE925
Alpine radio works fine, but only searches fm stations from 69 to channel 90. Most stations here start at 90 and go as high as 107.Radio is new, just bought on e-bay. traffic information is on AM!!!...
it sounds like you have purchased a unit that does not operate on our wave length, it sounds American, and all i can suggest is be careful where you buy things from mate, sorry, colin.
Dec 02, 2009 | Alpine MRD-M605 Car Audio Amplifier
FREQUENCIES
Typically, but not always, you can hold down a specific key on the front faceplate and hold it down while turning on the power. This will usually ONLY restore the AM channels from 9Khz spacing to USA 10KHz channel spacing, but I don't think it will restore the FM band; I could be wrong - do a google search.. Usually the FM band is Japan is different than ours, and there are some expensive adapters to upconvert/downconvert US FM stations, but not worth the money to add, in my opinion you should just buy a new tuner like the Sony HD radio tuner!
Apr 06, 2009 | Audio Players & Recorders
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
DOES NOT PICK UP FM CHANNELS CLEARLY
Does the receiver work for AM? I need to isolate the problem circuit. Please try an AM station and update this.
Thanks,
Dan
Jul 29, 2008 | Sony STR-DG510 DTV Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
Sony HDMI receiver STR-DG510
On Page 54/55 of user man. has a step by step instructions.
May 10, 2008 | Sony STR-DG510 Receiver
Manually tuning the reciever
you should be able to tune in manually.
press tune
press fm or am
press d. tuning
enter the frequency of the station 4 or 5 digits ie 9370 or 10450
another thing to look into would be getting a yagi fm antenna, they are directional and although you may have to rotate it for best results, they work great.
Nov 20, 2007 | Sony STR-DE985 Receiver
167 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
