Question about iLO (2 GB) MP3 Player
How to i write protect my usb from copying and deleting files by others...
    Genius:
  • 1,061 Answers
IN WINDOWS OS GO ..To my computer..click on unit..properties...tell it to write protect.RICHARDM69
Posted on Dec 18, 2008
How to protect copying files out of flash memory?
http://download.cnet.com/truecrypt/3000-2092_4-10527243.html
The ultimate freeware encryption program, TrueCrypt is loaded with powerful features that users concerned with protecting data from prying eyes will find robust and comprehensive.
Oct 06, 2012 | Electronics - Others
I CAN NOT COPY OR DELETE THE FILES OF MY USB
Your USB flash drive is either infected with a Virus or your Drive is Write Protected.
Scan your flash drive for Mal-ware and Viruses using an Up to date scanner.
Be sure to check that the drive is not on Write Protect mode.
However under Write Protect mode you should be able to copy file from your USB flash drive.
Also try the drive in another computer just to be sure it's not the drive that faulty.
damnor01 out!
Apr 06, 2011 | Computers & Internet
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I CAN NOT DELETE THE FILE, WHY? USB SAID REMOVE WRITE PROTECT. HOW TO REMOVE THE WRITE PROTECTED?
open the file try deleting all the other files around the specific file first
hope this helps
Aug 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Jsph just asked: how do i unlock my file which i filed in my USB were write protected? and I don't remember where did i get or copy the protected file. can i reformat the whole USB unit of 8G? and delete...
Before formatting you can try an option of dowmloading "Jet flash recovery' tool from transcend website and recover the files.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 22, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Delete write-protected file from usb
some... not all have a tiny switch on the side... move that to the other position and you should be abel to delete it. if that doesn't work... download a program called unlocker from
http://ccollomb.free.fr/unlocker/
Mar 21, 2009 | Electronics - Others
I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Dear Friend,
My Jetflash also writeprotected, there's no any solution for this in internet but I could solve this problem,
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
I could do it,
let others to know about this solution. Because I also suffered from this problem.
Amila--> +971559473812
asfonseka@yahoo.com
Feb 26, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
iLO (2 GB) MP3 Player Logo
15 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
ctcanFixYa
Level 1 Expert
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
