Question about OKI C9600hdn Laser Printer
Error 357 waste toner full
I have replaced waste toner unit with new one and still shows the error message as full so unable to print
  • Luiggie Feb 13, 2009
    I have the same problem. I first clean the old waste toner container but it doesn't work. So, I buy a new one, clean the area and install it but it still having same problem.
  • 95 Answers
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Posted on Mar 11, 2009
Replaced my waste cartridge with a new one and still getting error 357 waste cartridge full
See if your printer has some sort of reset button. contact Oki for tip.
Maybe you have to reload the software in printer. Try also unplugging printer while turned on. Then press and hold the power button for a minute or so. then plug back in and press power button.
Feb 15, 2016 | OKI C9600hdn Laser Printer
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
I have replaced waste toner unit with new one on a WC 5050 and still shows the error message as full so unable to print
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer.
NOTE: This should solve most problems with printers.
If still not working you have a faulty Toner unit.
Sep 21, 2013 | OKI C9600hdn Laser Printer
Can't not print. Please tell me .....why? i'm printting is suddenly: E1 CHG. WST. T. CTN i don't understand
This error message usually means that your waste toner storage is full and it has to be changed. If this is not done you will have issues with printing. Check your user manual and see where the waste toner container is and it will also give you numbers for reordering new container from manufacturers site. Hope this helps.
Mar 28, 2011 | Office Equipment & Supplies
Error 357
Hi - take the waste toner unit out and restart the printer. You'll now have a different error 'Check Waste Toner'. Open the front cover and put the waste toner back in. Let the printer go through the usual checks and hopefully all should be well.
In my experience this can be caused by not shutting the printer down fully before changing the waste toner.
JohnnySheffield
May 30, 2010 | OKI C9800hdn Led Printer
What is error 357 waste tuner box is full okidata c9800
The printer always puts out a little more of each color toner than is actually needed in printing. The excess gets dumped into the waste toner bottle.
The replacement part number for this printer is 42869401 and should last 30,000 pages. Order one from an OKI service center and it will come with the replacement directions.
I hope this helps.
Apr 18, 2010 | Office Equipment & Supplies
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
OKI C9600hdn Laser Printer Logo
1,812 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
