Question about Korg Legacy Collection
Korg i5s-no sound
My korg i5s has developed a problem. When it is powered up the display screen is saying ''low battery''. Also no sound is comming out of the board, but all the display is showing up on the screen.
4 Suggested Answers
  • 68 Answers
SOURCE: sticky keys on Korg extreme
Unplug the unit. Apply small amounts of isopropyl 99% (or 91% if it contains no emollients) using a dropper or try with a High-Quality cotton swab as you depress and release the key. If it helps, make sure it dries completely. The alcohol will evaporate quite rapidly. Works well for Red Bull and Jaeger Bombs dropped on the keys.
The Triton LE has a similar key structure to the Karma and some Ensoniqs. It is actually VERY EASY to a tech with minimal experience to open it up and clean the contact of a key that has gotten too dirty. Broken keys are also very easy to replace. It is not easy to destroy your keyboard by opening it and taking a look. When you shake it, can you hear a small piece of plastic rattling? Maybe it broke. www dot korgparts dot com has replacement keys and I think even manuals and stuff. FYI - the Triton and LE use different keys.
Posted on Jun 07, 2008
akubeda
  • 4 Answers
SOURCE: Problem with Korg PA-50
Try to download the Operating System from http://www.korgpa.com/pa_root/en/products/pa50.html?en
Posted on Apr 08, 2009
bryand1
SOURCE: Low battery voltage issue
I just replaced mine. Your keyboard will not self-destruct. Go to Radio Shack and buy a CR2032 ($5 or so). Turn your TE over. Unscrew the hatch. You'll see the battery is in reachable distance. Pop it out. Put the new one in. That's all.
Posted on Jun 11, 2009
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
Apr 05, 2016 | Korg Music
How do I print attachments embedded in websites using Windows 10?
when you push print, screen will pop up either the option will be where you can see it or if the printer company will put it into options.
your looking for box to put a check mark
the statement says the following statement:
print background colors & images
Oct 07, 2015 | ASUS Computer International Asus...
I need to factory reset my X3
update it or flash with new latest files
Mar 21, 2015 | Music
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
Korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Oct 30, 2011 | Korg X5d
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
Computers & Internet Logo
275 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Hardware and...
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
