Question about Frigidaire 27 in. Electric Gallery Pro Series Single Self-Clean Wall Oven
My Frigidaire wall oven is not heating
I have a Frigidaire, Professional Series wall oven
Model # CPEB27S9DC2
Serial NF53813513
Conventional /Convection
It is not heating - No reaction for the conventional mode
Fan blows & lists Pre for convection with very little heat
What is wrong? Do I need to replace a part?
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
If this oven works the same as the 302T, the bake element is not used during convection mode, only the convection element.
The cooling fan must come on
The air switch must close
The convection element must be good
I would suspect the element first.
Post back and let me know what you find out.
Posted on Nov 16, 2007
  • 291 Answers
SOURCE: Frigidaire Oven making vibration noise when
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: my 2006 frigidaire professional series
To properly troubleshoot thid you will need to check to see if there is voltage going to either of the elements...it is unlikely that both have filed, but it is possible...so check that first... if you have 240v across the two ends of the element then the element is bad...
If you are not getting voltage to the element then the clock/timer is bad...
Here are all of the parts for your Oven
heatman101
Posted on Dec 19, 2010
heatman101
  • 43501 Answers
SOURCE: I have a new wall
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Mar 06, 2011
The oven was cleaned recently. Since then, it will not heat up. Instead 135 and prebake, on appear. Cannot get rid of this. Help?
Hey Mark, thank you for your submission!
Based off the information you have provided your Frigidaire oven is no longer heating up after it was cleaned. The oven may need to be reset in order to help clear out any miscommunication. In order to reset the oven you would need to flip the household circuit breaker off for at least ten minutes. If the reset does not help clear out your issue I would suggest seeking assistance from a professional technician. You can locate a technician in your area from your manufacturer's website. I hope that this information is helpful. -Matt
Feb 21, 2016 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery series oven
what is the model number is then we can get started then okay??
Sep 02, 2013 | Ovens
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Quit heating
Hi getalifemom - From what you have described it sounds like the unit has faulty element(s) or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues and properly diagnosis the unit.
Jan 18, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven
Sounds like your control board/panel has shorted out. You would definitely need a professional to diagnose correctly and properly repair.
Dec 26, 2012 | Frigidaire 30 in. Electric Gallery Pro...
Wall oven is not baking properly
Look in your Owner's Guide to see if the unit you own has a way to configure or calibrate the temperature yourself before contacting a professional.
Jul 18, 2012 | Frigidaire Ovens
Frigidaire 27 in. Electric Gallery Pro Series Single Self-Clean Wall Oven Logo
258 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
