Sharp ar163 connect with PC
I can't connect my copier with the pc I bought bridge to convert from com to USB and install the driver for the copier and the driver for bridge but the copier no work
please help me
  • 1 more comment
  • alabsari Dec 22, 2008
    i have parrallel port 25 and i used bridge to convert from parallel to usb
    I have parallel port 25ports and i used bridge to convert form parrallel to usb
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does your copier have a usb port or an ethernet port?
  • 2,794 Answers
You might have a problem running it that way. I use a parallel print server. They come wired or wireless. That way you won't run into any compatibility problems with the print drivers.
It will run faster too because the spooling can be controlled better through the copier.
This is the recommended way by Sharp as well.
Posted on Dec 22, 2008
HOW DO i CONNECT MY PC TO sHARP Ar-287?
You might be able to connect it USB or with a parallel cable. Most computers nowadays don't have a parallel input, so you'll need some sort of converter.
Most of those machines were copier only, though, and you'd be hard pressed to find a print controller for it in 2015. http://www.copercollin.com/
Sep 26, 2014 | Sharp Office Equipment & Supplies
Retrieving camera data to pc to edit and record to dvd
You need a program that will capture data from your camera to the hard drive. Pinnacle Studio will work with your camcorder. Insert USB or firewire cable into your camera and into you computer. Once you turn the camera on and the software has been installed, a dialog box will come up on the screen requesting you to load up the studio program.
Aug 13, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
WANT TO CONNECT MY SHARP COPIER AR5320E TO MY PC FOR PRINTING AND OTHER RELEVANT USAGE
first insert the installation cd and install the driver then connect the copier to pc with usb port.
Aug 07, 2010 | Sharp AR-5320 Black and White Copier
How can make a connection between the machine and computer
first you should install the copier`s driver on computer then connect the copier to pc with USB cable then use it.
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
We are trying to connect the Desk top PC so as to use AR=5316 as a printer.Need help to install the printer software. Can I get it downloaded from Sharp site. Please reply.
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
Apr 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
Compatibility with a Mac.
You can use it as a printer if you have a USB port or an ethernet connection if you have your copier connected to the network.
Scanning probably isn't available.
You can get printer drivers at sharpusa.com
Oct 20, 2008 | Sharp AL 1631 Copier
USB to ATA/ATAPI Bridge
1)solve and proper connecteted usb in usb port
2)not detected additional usb cable in communication port(com1)connected
3)ceque virous affected this system.then re install in new OS.
Sep 25, 2008 | Computers & Internet
Printer am 900
Remove the driver, button manager and sharpdesk then reinstall. Be sure to unplugged the usb connector from pc. After the installation step ask you to connect the usb or restart the pc, plug it.
Jun 11, 2008 | Sharp SHP AM900 multifunction Printer
78 people viewed this question
jasbo
jasbo
