Question about Samsung TV Remote Control
The remote control batteries keep going flat on my Samsung tv 348
When I first inherited this old TV the remote would hardly work at all and the batteries would go flat after a day or two. I pulled the remote apart and cleaned every thing and now it works fine but the batteries still go flat. Can't find a user manual anywhere for it. A new remote is $90- better to by a new TV for that money, a generic learning remote is $25 but does not have all the functions. Any simple answer you can suggest? Thanks!
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
  • 1214 Answers
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
Posted on Jan 29, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
SOURCE: Samsung remote won't turn 630 LCD off. Only volume works.
yo moel
the way i did it was take the batteries out and hold powere button for 5 seconds put batteries back in and should be fine mate!
ahmed
Posted on May 17, 2010
Samsung 40' tv remote wont change channels the batteries are new and i get a weak no signal on the tv screen
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 21, 2014 | Samsung Televison & Video
The tv changes it source from cable to pc all on its own with no use of remote and the volume will not work
first disconnect the remote battery, if same problem then you have to take off the buttons on the tv and clean them from inside !
TV Repair Service Television Repair Tv Repair Toronto Mississauga...
Jan 13, 2014 | Samsung LN40B530 40 in. LCD HDTV
My mute setting on the tv keeps going on and off on its own
Look for any jammed buttons on the remote or on control panel. Try removing the batteries from the remote and see.
Aug 05, 2012 | Samsung New 60"" Class 60.0"" Diag. Led...
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
I have a Samsung 32 inch LCD tv that constantly changes channel on its own. I switched it on this morning and it was working fine then the volume went to max and I couldn't turn it down. I then switched it...
You say the remote doesn't work but it may well be the problem. Take the batteries out of the controller then try using the tv using the controls on the TV.
Dec 02, 2010 | Televison & Video
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Samsung Remote BN59-00539A not working
Remote Control not working with dvd plyer
Mar 25, 2009 | Samsung BN59-00599A Remote Control
Samsung 52....TV will not turn off
Call who you bought the TV and remote from and get it replaced with there warranty. No reason to put yourself through a headache when you are covered under warranty.
Feb 22, 2009 | Samsung Remote Control
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Samsung TV Remote Control Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
