Question about Canon PowerShot S300 / IXUS 300 Digital Camera
Equivarent battery NB-1L,The place has no such a battery.What kind fits for that?
    Scholar:
  • 66 Answers
It seems to be from a cannon but here is a replacemet site to go to for that exact battery.
http://www.power101.com/search.htm?search=nb-1l
Hope this helped......Kevin
Posted on Dec 18, 2008
My wash machine miele W145s is stopping washing when comes to rincages point. The lamp is flashing. Have somebody any suggestions in addition to buy new one?
Look in to filter housing and check that no debris is entangled in the pump impeller also check the drain out pipe for blockages
Dec 26, 2014 | Miele Washing Machines
Tip
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
How is the New Balance 801mule different from the cws473?
This sort of information is almost a secret. It takes persistence to get that kind of information out of New Balance.
if you are sold on getting a new balance shoe, then go to a Procare certified store and see if they can help you.
otherwise, check with stores that sell orthopedic footwear and clogs.
Jun 18, 2013 | New Balance CWS473 Mules & Clogs Shoes for...
I am unable to find a new battery that works in the camera. Original Battery: Canon NB-4L 3.7V 760 mAh I have tried two different: Flashpoint NB-4L 3.7V 890 mAh to no avail
You can order the NB-4L battery from Canon at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd450#SuppliesAndAccessories
(If FixYa screws up the formatting, go to http://www.usa.canon.com , enter "SD450" into the search box, then click on "Supplies & Accessories".)
You'll also find a variety of third-party options at
http://www.overstock.com/search?keywords=canon+nb-4l+battery
Feb 14, 2011 | Canon Powershot SD450 / IXUS 55 Digital...
Can i upgrade the battery on my canon zr200? i currently have the nb-2lh, but i would like a reliable battery that lasts longer.
What's the capacity of your current nb-2lh battery,will a 800mAh canon nb-2lh battery that allow you take at least 200 photos meet your needs.Search in google and find the best.
Sep 29, 2009 | Canon ZR200 Mini DV Digital Camcorder
Camera won't power on.
That's what it would do if the battery had no charge. Batteries can only be recharges so many times. Pick up a replacement battery. If that doesn't solve it, at least you'll have a spare battery.
Sep 22, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
Need to charge battery, lost charger. Can I use the usb cable to the computer to recharge battery??
I'm in Burundi where there's no NB-1L Battery.Is there any equivarent mobile phone for changeing?
Dec 18, 2008 | Fuji FinePix Z10fd Digital Camera
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Canon PowerShot S300 / IXUS 300 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
