Question about Amana ALE643RB Electric Dryer
Rag lost under dryer filter
HI, i removed my dryer filter and noticed a lot of dust balls at the bottom of the casing that holds the filter. i wrapped a small, damp rag (a 1/4 length of facecloth) around a stick and tried to clean out the debris, as my vacuum hose extender would not reach that far down. i lost hold of the rag and it just seemed to disappear. i think that it may have gone into the dryer motor area. i am afraid to start the dryer, in the hope that it will be forced back toward me. this happened when the dryer was new. someone forgot to replace the filter and a sock got into the same area and stopped the motor. however, when the repair man came, he removed the sock in about 2 minutes. i didn't watch to see how he accessed it. i would like to try it myself and avoid the $125. service charge. would appreciate your help. thanks, sall modl #AlE643RAW not listed on this site.
  • adel sal Apr 02, 2007
    thanks catriver.......i many still try this, however, i made the mistake of leaving for a while and not unplugging the dryer. another family member did 3 loads of wash and used the dryer successfully.
    now, i'm not sure if this might start a fire or the dryer will eventually implode or stop. clearly, the bright orange rag, which was out of view, must be causing havoc somewhere.
    sounds like you'r ea true expert, one of these days, i might post my frig issue.
    thanks again......
    President:
  • 878 Answers
Sall, there should be a lower panel on this dryer that can be removed. Two screws on the bottom and it should pull out and down. Once the panel is off you will be looking at the blower housing. With the filter out, remove the screws securing the blower housing and lift out. Now the blower wheel is exposed and you should be able to see the rag. Catriver..post back.
Posted on Mar 30, 2007
How to clean air filter?
There is a rectangular grille with a small notch where you can put your finger and remove it.You will see a black sponge filter under it on a frame. Remove the frame and use a blower to blow off the dust. You can also hold it under running water to displace the dust but remember to hold the sponge both ways under running. The important thing when you do wet cleaning is to make sure you dry it properly in the sun or with a hair dryer before you replace it.
May 07, 2011 | Hitachi CP-S225 Multimedia Projector
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
MY Hotpoint WD 640 washing machine is not drying clothes is there a filter to clean or a reset
Feb 15, 2010 | Hotpoint Aquarius WD640 Front Load...
WD440 HOTPOINT AQUARIUS LEAKING FROM FRONT/NOT DRYING
The leak in the front could be from one of the tubes bringing water to the detergent box; you should open up top to locate.
Jul 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Remove debris from around the outside of drum
Take the top off the dryer. You can access it from the back and remove the screws. You will probably find a lot of dust as well. You can also lay the dryer on its frontside to get to the bottom. There isn't going to be anything you can damage here. Vacuum it well especially around the motor.
Feb 07, 2009 | Whirlpool Dryers
Condenser dryer gets hot but cloths not drying and water drainer
Check The Ducting To Make Sure There Is No Obstructions Inside. Find The Outlet Outside Where The Duct Goes And See If Your Getting A lot Of Air. In Some Cases You May Have To Remove The Back Of The Dryer To Remove The Biggest Lint Ball In The World.
This Huge Lint Ball Builds Up Over Time And Quickly For Users Who Do Not Clean The Lint Trap On Every Cycle.
All Of The Above Will Cause The Dryer To Not Be Able To Get Good Air Flow Thus Causing The Machine To Have To Much Back Pressure.
Feb 04, 2009 | Candy DQW150 Front Load Washer / Dryer
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=765231
Generic problem for all Vacuums
I have a 6 gallon
Posted by tsfroggy on Jul 10, 2008
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I wrapped a rag around it and made it secure. Respectively: TOM
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The bag is not going to do the job as well as the filter around the drum that hold the ball. The filter that goes under the motor does a lot of the filtering or you would have to do some type of cage filter then a foam filter and then a paper bag, I f you have a cartridge filter then the paper bag can go over the cartridge filter , B4 you do anything – id you have some type of compressor – use it to blow out the dust and dirt out of the motor, then buy a cartridge filter and then a paper bad with a rubber band to hold it on. This will do the best filtering . Check with your local vacuum cleaner dealer and bring in the top of your shop vac so that they can fix a proper cartridge / paper bag filter – or the cage frame with a foam filter with a paper bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Cycle is stopping at 9 mins left and not spinning on my lg drive 7 washer/dryer
A common solution for filter cleaning, might help you. You should check your pump too. (another Hotpoint model)
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
May 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Amana ALE643RB Electric Dryer Logo
214 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
