Question about Epson FX 1170 Matrix Printer
Do i can customize my paper size in MS Excel 2003
I have a problem with my printer set up, i am using epson fx1170 and i am printing with the size of 15x12 inches, how do i can customize my paper size in MS Excel 2003, the default size in excel is LETTER, LEGAL, A3, A4, A5, B5 (JIS), US Std FOLD, FANFOLD 8.5X12in., how can i customize my paper size with the size of 15x12?
  • 36 Answers
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Posted on Jan 05, 2009
Epson Stylus R350 in Custom Big Paper
in printer properties, specify the paper size, and or demand for the print to fit paper size, in the printer properties
Mar 22, 2010 | Epson STYLUS R350 Photo Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Will not print to size
There are "default" paper options that can be set from the epson software you may need to alter these to suit your regular paper size.
Also if you are printing from MS office you can select sizes from there too.
It is better if both are set to the same.
Aug 11, 2009 | Epson Stylus Pro 4000 InkJet Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Jan 01, 2008 | Epson LX-300+ II Matrix Printer
Printing on 4x8 cards
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
Oct 12, 2007 | Epson Stylus RX580 InkJet Photo Printer
Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
Paper size..
In WIN98 with WordPerfect9 we had set up dot matrix printer Epson LQ1050 on which to print 8.5" wide by 5.5" long (half page) multipart invoices. In XP apparently MSFT changed this and there is no custom paper size in windows printers. Instead one must use the program's (Word Perfect) page setup where the page size can be entered. Problem is the Epson drivers have not been rewritten to incorporate this change. The optional paper sizes are builtin to the printer drivers. Some folks with the same situation as you have had success using the Forms menu in MS Fax to set different paper sizes. Third party programs such as FinePrint (www.fineprint.com) can also help with this. I hope you work it out ;]
Apr 23, 2006 | Epson TM U210A Matrix Label Printer
Epson FX 1170 Matrix Printer Logo
1,455 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
