Question about Brother MFC 7420 All-In-One Laser Printer
Paper jamming mfc-7420 paper constantly jams
  • 1 more comment
  • Anonymous Jan 22, 2009
    I have the same problem. Every time it prints it crumples the page up at the back door. I have checked and there is no obstruction.
  • kcs north Feb 06, 2009
    I have two clients who are experiencing this problem. I cannot see any reason.
  • Carolyn Rosenstein Apr 27, 2013
    this is the problem that I am having, although it doesn't always do it. It seems to happen on the first page that it prints after it has been at rest for a while.
    Champion:
  • 320 Answers
Tell me where it jams so that i may help you! brother tec
Posted on Jan 13, 2009
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Our brother MFC 7420 constant jaming of the paper when trying to print, what causes this?
clean the drive wheels that pull the paper in, they get shiny after a lot of use, use a alcahol pad to clean
Mar 08, 2011 | Brother MFC-7820N Laser Printer
Mfc-7420 says paper jammed/ and no feeding paper -all faulse messages-no paper there jammed
This is a huge problem, not only with the MFC-7420 printer, but literally every printer known to exist! The best way to solve this problem is to look at where the printer is connected. If it's connected to your computer, it may be trying to print something from there still, causing the information that the printer is receiving to become jumbled up and confused. I'm going to go step by step to try to help you out of your printer misery:
First: Unplug the printer from your computer entirely. Then unplug your printer's power source.
Second: Re-plug back in your printer's power source, and wait for it to turn on fully.
Third: Double check to make sure everything is working fine aside from the non-existent "paper jam."
Fourth: Re-plug back in the printer to the computer, and cancel all scheduled prints that are queued on your computer.
Lastly: Retry printing!
Hope this helps.
-Anonymity
Feb 24, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 - paper jams in fuser unit -
Its probably the pickup roller and/or separator pads. Another possibility is a tear in the fuser heat cover. IF you can manually rotate the fuser(when its cool) you can see if the fuser roller has any problems. Last thing is make sure its looking at the right paper size. Maybe reset all software settings and start over? If its looking for one size and seeing another, it may cry jam.
Feb 02, 2018 | Brother Office Equipment & Supplies
My MFC-7420 jams paper after each copy what is the problem.
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
May 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jams 1/2 way through drum/cartridge. Jams like an accordian, with 1/2 page printed. My printer is a Brother mfc 7420. About 2 years old.
Take the toner cartrige out, look around with a flashlight for a piece of paper or something that could jam the works. Check the movable tab that comes out of the front of the machine to hold paper up, maybe it has gotten crooked or something. Don't have anything in front of the machine to block the paper coming out. A can of compressed air can be used to blow the machine out.
Apr 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420 constant paper jam
need a little more info on this. does the paper look like it catches on something? is there any nicks or anything on the lead edge?
razors
Jan 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
677 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
