Question about Sony Cyber-shot DSC-W50 Digital Camera
Flash doesn't work
My camera shows the icon that the flash is on but when I take a picture that is in the dark, the flash doesn't work. What could be wrong? Thanks, Laura :)
  • Laura Baeza Mar 28, 2007
    UPDATE.....I fiddled with my camera while I was waiting for a reply from this site and got my flash working. I had enabled the arrow down symbol and that was preventing the flash from working. It works now! Thanks so much for your prompt advice. Laura :)
    Sergeant:
    Champion:
  • 326 Answers
In order to repair the above mentioned error you should replace the flash circuit board part number:A1166208A.Price for the spare part is 35 Euro (for my account). If you need more info please advice.
Posted on Mar 28, 2007
    Novelist:
  • 198 Answers
Hello Laura, Try to hard reset the camera at first. This can be done by removing the battery and pressing the power button for about 1-2 min (keep it pressed). After that, press every other button twice (including zoom, menu and shuter buttons). Then press again the power button for about 1-2 min. After that reconnect the battery and go to auto-settings. If this doesn't work there is a problem with either the camera's firmware or the internal flash capacitor. Either of these will require service intervention because they will need to dissasemble the camera and run a diagnostic. This shouldn't be an expensive repair IF the camera doesn't show on the screen an error message something like E:16:00 blinking (when you take pictures). If this is the case, the flash assembly is damaged and needs to be replaced (this costs about $50-$60) otherwise it should be cheaper. For more informations please reply back.
Kodak c875 digital camera: flash has stopped working and not able to take pictures in dark. flash on icon comes on screen but pictures are dark and no light flashes may be need to replace bulb but how and...
Replacing the flashtube is not something you can do. It requires complete disassembly of the camera and delicate soldering skills. It must be sent to an authorized Kodak repair facility. It will cost a lot.
Jul 15, 2011 | Kodak EasyShare C875 Digital Camera
My pictures are coming out very dark at night despite having the flash on. Not sure if I accidentally changed some setting or what. There is an icon at the bottom, middle of screen that looks like a hand....
The hand icon may be a warning of low light or about stabalisation if your camera has this feature. You don't say what model your camera is, but Canon usually use a jagged arrow icon, like a lightening bolt, to indicate the flash is on. If this is blinking, then the flash is still charging up. Does the camera actually flash? A low battery may prevent the flash from charging up enough to provide the light needed. In any case, flash only works for subjects that are reasonable close up.
Oct 25, 2010 | Canon Cameras
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Jan 28, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
Flash issues
If the automatic flash settings detection is on where possibly isn't dark enough.. Try to go into a completely dark room and see if it works.. If it still dont work try and check the camera settings..
Mar 11, 2009 | Sony Ericsson K800i Cellular Phone
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Flash doesn't work
You may have selected "Flash output" - look that up in the camera settings. In M mode, go to the menu, go to [flash +/-] icon, adjust flash with left and right arrows and press FUNC. You can take test photos while adjusting with the arrows.
Also, the effect of the flash quickly diminishes with distance so if your objects are distant the built in flash is too weak to light them, but the camera has no way of knowing this. In contrary, when not using the flash, your camera adjusts its exposure to the amount of light available (hold the camera steady!)
Jan 15, 2008 | Canon PowerShot A95 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Flash doesn`t work!!
In warranty case however, in order to repair the above mentioned error you should replace the flash circuit board part number:A1166208A.Price for the spare part is 35 Euro (for my account). If you need more info please advice.
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
144 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
