Question about Ricoh Aficio SP C811DN-DL Printer
Service Call SC548
Our colour Ricoh SPC811DN printer displays the following error message:
Service Call SC548
Please Call Service
HOW CAN WE REPAIR THIS?
THANK YOU
  • 161 Answers
Fuser problem . danger . call tech
Posted on May 06, 2009
  • Bernard D'Souza May 06, 2009
    Fusing unit rotation error
    paper jam --remove the fuser and slowly check if the knob can turn properly
  • 183 Answers
Well it says call service so you cannot repair this
Posted on Jul 16, 2009
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Error message
It's the fuser. You can try turning it off, wait 30 seconds, and turn it back on again.
If the problem continues, call a technician in to get the thermistor replaced.
It's a common error.
Posted on Aug 04, 2008
My Ricoh SPC811 DN shows always an error code SC491
hi
this error code is about "Cooling fan motor lock", we have 2 Reason for this code,1: Cooling fan motor defective or a loose
object is interfering with the fan and 2: Poor fan motor connector connection
please check them
Oct 06, 2013 | Ricoh Brand Aficio Spc811dn WASTE DISPOSAL...
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
Error code SC220 for ricoh spc811dn what do I do?
sc220 is a laser sync error. You'll probably need to either replace the laser sync board or the laser diode itself, so you may want to contact a local service technician, as both of these components are internal and can be slightly tricky to get to.
May 13, 2011 | Ricoh Aficio SP C811DN Laser Printer
My Ricoh Aficio SPC811DN printer keeps asking me to replace my PCU colour all the colour carteridges are over half full what do i have to rplace
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Jan 18, 2011 | Ricoh Aficio SP C811DN Laser Printer
Copier mp3500 rex rotary ,i want to remove the authentication ,it displays sc548 contract serial no of march M2772901444
This a fuser (hot section) error code that need you to enter service mode to clear, -Carl
Jun 04, 2010 | Ricoh Aficio 450 Copier
I have problem with my copier aficio 450,sc548 appear,please help me solve this error
SC548 is a fusing unit installation error. The machine can not detect the fusing unit for some reason. Did you have the fusing unit out of the machine? Like to remove a paper jam? In case you do not know the fusing unit is the part that gets hot. Located right before where the paper exits the copier. It comes out the front of the machine when you have the front door open. If the front door is open it is in the upper right corner and should have a blue knob on it. Make sure this unit is all the way in. You also may have a wiring or connector issue causing this as well.
You will have to enter the service mode to reset this code.
CAUTION: Do NOT mess with this service mode in any way other than the specific function I give you. Doing so could result in damage to your machine!
Enter SP (service mode) by pressing yellow C button, then press 1 0 7 on numeric keypad and then hold down the orange C button, display will change and then from the menu select "copy SP" then type in 5801 and press #, then press "execute". Turn power off and back on. If the code is gone and the machine works then your fine. If it comes back you will need to call a servicing company and have them repair the machine.
Good Luck and Thank You for using Fixya.
May 15, 2010 | Ricoh Aficio 450 Copier
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
My Ricoh SPC811dn is displaying a message : Set the fuser unit correctly, how to I solve this?
Pull the fuser out ....look around inside the fuser cavity I belive on the left lower side as your looking in..... your looking for a sensor that is knocked out of its bracket...... reinstall sensor and fuser and you should be good to go
Nov 19, 2009 | Ricoh Aficio SP C811DN Laser Printer
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Error message
Aug 04, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN-DL Printer Logo
1,529 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
