MY E DRIVE HAS DISAPPARED FROM MY COMPUTER (LAPTOP) AND I CAN NO LONGER USE THIS - NOT READING WHEN INSERTING DISCS EITHER. LAPTOP IS ACER - AND INFO FROM DEVICE MANAGER REGARDING THE E DRIVE IS AS FOLLOWS: OPTIARC DVD RW AD-7530A ATA DEVICE DEV TYPE DVD/CD-ROM DRIVES MANU STANDARD CD-ROM DRIVES LOC LOC 0 CHANNEL 1, TARGET O, LUN 0 THE ERROR MESSAGE READS: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available. HOWEVER WHEN I CLICK FOR SOLUTIONS NOTHING HAPPENS. HELP!?
    Scholar:
  • 111 Answers
The following worked perfectly in restoring the CD-ROM drive:
The following steps were posted by skidzy on the pcadvisor.co.uk forum:
http://www.pcadvisor.co.uk/forums/index.cfm?action=showthread&threadid=284747&forumid=20
Follow these directions for clearing the Upper/Lower Filters: (might want to print this out)
1. Click on Start --> Run --> and type in 'regedit' followed by the enter key ( if Vista Start search or windows+R )
2. Expand the "HKEY_LOCAL_MACHINE" key (looks like a folder) by double clicking it (or
3. clicking the "+" next to it.)
4. Expand the "SYSTEM" Key
5. Expand the "CurrentControlSet" Key
6. Expand the "Control" Key
7. Expand the "Class" Key
8. Please look for a key containing the following string of letter and numbers:
{4D36E965-E325-11CE-BFC1-08002BE10318}
9. High light this key by left clicking once on it
10. On the right hand side you are looking for "UpperFilters" and "LowerFilters" under the "Name" column, once you find these please delete them by right clicking on them and choosing "delete"
11. Please exit the registry by clicking on the "X" in the top right hand corner of the screen
Reboot your computer.
If in any doubt editing the registry,please create a System Restore point first and also backup your registry.
Posted on Dec 18, 2008
My TSSTcorp DVDWBD T3-LB23A optical drive is no longer reading any discs, though it spins and tries when I put a factory movie DVD in it. Same with CDs. The system does boot up the same movie on an
when a drive stops reading ANY disk it's most likely a bad drive.
if the computer see the drive and ask for a disk, the software and disk driver is operating correctly. laptops generates a lot of heat,and more so when pluged in and charging. CDs,DVDs, and disk drives also generates heat. proper ventalation and a cooling pad will help extend the life of a laptop. if you have acess to a spare laptop drive, you can swap them. windows-7 will see the new drive and should install driver.
Sep 12, 2012 | Computers & Internet
My ps3 not reading a discs need the answer plaeas
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Aug 20, 2010 | Video Game Consoles & Games
Dvd does not play
The most common reason for the Laptop not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your DVD, or issues inserting your DVD or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Laptop including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Laptop going again!
Hope this will help...
May 31, 2010 | Dell Inspiron Notebook
My built-in dvd will not work.
hello,
The most common reason for the system not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your system including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your system going again!
Hope this will help....
May 30, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
My hpf1905e is no longer uploading pictures from
pls check on the device manger after inserting memmory stick
if any yellow colour is there.you should install drivers for memmory card
Oct 30, 2009 | HP Pavilion dv6000z Notebook
My macbook isnt reading any discs.
There seems to be a problem with the superdrives in the MacBooks. I had mine replaced under extended warranty last month. If your Mac is under warranty, bring it in to the Apple store.
Several macbook users in the past have had success with their optical drive reading disks by turning the laptop upside down and then inserting the chosen CD. Might as well give that a try in your situation.
Drives are available online. Let me know if you need instructions on how to r/r the drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My DVD drive is no longer recognized
could be a cable has come loose or the reginal settings have been changed
Mar 02, 2009 | Acer Aspire 5100 Notebook
My ps3 system recently stopped reading any discs
i have got the same problem, you can either get a new blue ray lens and fit it yourself or give sony a ring and they will change your console for you.
Nov 24, 2008 | Sony PlayStation® 3 (60 GB) Console
Disc drive wont work
It sounds like the laser may have went out. When reading a disc the laser moves up and down as well as back and forth. It sounds like it is reading from the wrong position if it's reading at all. Remove any disc from the drive. Go into the device manager and remove/uninstall the drive from the list. Reboot the computer, wait until the hardware wizard reinstalls it and then try reading another disc. If this doesn't help then most likely the laser has went bad. It is not an uncommon problem. You can also see if there is a firmware update for your drive from the maufacturers website or your PC speciffic website. Hope this helps.
Sep 22, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
