The ac wasnt working, we turn it on the light just flases, so we tried charging the ac, still blows hot air but now when we turn the ac on it blows the fuse to the gas and temp gage. so we replaced the fuse, and DID NOT turn the ac back on but the fuse blew again by itself, so we took the fuse out that goes to the ac, and now the gas and temp gage stay on but how do we fix the ac? any suggestions??
SOURCE: 1997 Chevy Cavalier Z24 2.4l
did you check the gauge that could be bad and did you check the thermostat thaat could need replacing
SOURCE: 1998 chevy malibu fuse question
Sounds like you have a ground problem, i doubt its in the sending units as both gauges are acting strange work, seeing that electricity likes paths of least resistance one gauge could be grounding through another. Bad grounds wreak havoc on electrical systems.
SOURCE: Temperature gauge fluctuates and the heater blows cold air
Sounds like the thermostat needs to be replaced. If you do the work yourself be sure the temp threshold is correct and the flow direction is correct when installed. Good luck to you
SOURCE: Driving the temp gage goes into red area, pull
Could be a plugged heater core, or bad water pump.
