Question about Canon DM-XM2 Mini DV Digital Camcorder
Difference between 16 & 12 bit analog signal
What is the difference betwwen 16 bit analog input signal and 12 bit analog input seginal ?
  • 10,594 Answers
In audio 12 bit selection, you can add audio (audio dub) without deleting or damaging original sound track. Like narrating some introduction in your voice and keeping background / original sound as well. 4 bit difference is used to add additional sound in same sound file without deleting previous audio data.
16 bit audio selection will not give you this option and audio-dub option will be disabled. If you want to add more audio, you have to over write complete sound track in movie file.
I'm not sure that I conveyed it to you correctly. Need further info, let me know.
Posted on Dec 18, 2008
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Analog Audio Out signal has very high distortion. Signal wanes in and out, wanders from one channel to another, and develops high static. This happens when Audio Out is configured for Fixed Output. When...
The problem is more likely to be with the wireless headphone set rather than the TV. It makes no sense that the signal changes channels. The only difference betweent he fixed and variable output is whether or not the volume changes the output signal amplitude. The channel selection process is not handled there. The distortion is likely due to the input of the wireless being overdriven. If available, turn down the input gain on the wireless and try again. Please update this with the results.
Thanks,
Dan
Feb 28, 2011 | Televison & Video
Tell the difference between the Aux input and V-Aux input
'Aux' is a general label for any Line Level analog stereo input like DVD, VCR, TV, DBS, etc. They are usually electrically identical and interchangeable except for PHONO.
V-Aux on this unit is on the front panel for conveniently connecting a video device. It has analog and assignable digital audio plus S-video and composite video.
There is nothing labeled 'Aux' on this unit.
Feb 16, 2011 | Denon AVR-2807 Receiver
What is the difference betwwen the hayward C900 and the C1200. I current have a C900 and the pool has a 1 1/2 hp pump I was thinking of and up grade
Most pumps are sized to the plumbing and filter size. If you go with a bigger pump and don't have the right size plumbing you can downgrade the water flow and create cavation noise in the system while actually getting less flow. If the filter is to small for the new pump you can get the same thing along with the bonus of hurting or cracking the filter. This is where you may want a pro on site (not Johnny One Truck) to help with this decision.
May 19, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
Need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
Nov 12, 2008 | Televison & Video
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Canon DM-XM2 Mini DV Digital Camcorder Logo
99 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
