Question about PC Chips M863G Motherboard
I have a PC Chips M863G Mobo wont see floppy
I'm trying to install a SATA PCI card and fresh XP copy, but this thing wont recognize the floppy to load the drivers. Any ideas? It's all plugged in correctly. I never use the floppy, so I dont know how long its been like this.
    Problem Solver:
  • 7 Answers
Download windows for with no need floppy, and boots from your cd'rom
Posted on Dec 18, 2008
FUJITSU MHT2060B-SATA hard drive driver wanted
Get the drivers from the motherboard homepage, extract the file at a floppy or USB, and start WinXP installation from your cd. At the begining at the bottom line is a message like "for ... drivers press F6 to install" Press F6 and after sometime the will prompt you to provide the drivers from the floppy. In the WinXP sp3 the generic SATA drivers are already on the installation cd.
Stelios
Feb 18, 2010 | Fujitsu (MHT2060BH ) 60 GB Hard Drive
I have a Toshiba Tecra S3 laptop with a standard Toshiba SATA hard drive (MK6032GSX rv. AS311G). It was a corporate hand me down. It is in dire need of a re-format due to age and virus but when I try it...
Windows XP does not have the SATA driver on the install CD.
You need to download the SATA driver for your model laptop from the Toshiba WEB support/download page.
If the laptop has floppy drive, then copy the SATA driver to the floppy and when you boot up with the Windows XP install CD and then press F6 to install the SATA drivers which is on the floppy as instructed..
Oct 30, 2009 | Computers & Internet
I Have a chips m863g v 5.1 motherboard but can't seem to locate the pci modem drivers for it. need help locating the drivers for it
If it has a pci slot modem card then you would go to the modem card manufacturer's website to download the driver. You'll need to know the manufacturer & model # of your card to do this. Once on the website you will click the support link, lookup your card model #, & then download & install the proper drivers for the operating system you are running. Hope this helps.
Mar 30, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Asus P4S800D-X mobo and sata hdd problem
I believe you need to load in the SiS 180 RAID controller for this MOBO during the Windows Install.
Do this by loading the driver onto a floppy and pressing F6 when told to do so by the windows install.
Mar 20, 2009 | ASUS P4S800D-X Motherboard
Wont load
It is on your os problem. Insert your OS installer. You don't have to install a fresh copy but you can repair your previous OS installation. Make sure you have set your boot sequence to CD, floppy and last HDD. You can now reinstall your drivers after doing that.
Dec 21, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Restoring dimension 9150
Yvon,
It sounds as if your restore partition has become corrupted. You vcan Contact Dell and order a restore disk
As far as trying to Install from Install CD goes. Well Win XP does NOT recognize SATA drives natively. You have to install the sata drivers to get them to appear. You can download them from the link below.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=XPS/DIMENSION%20400/9150&os=WW1&osl=en&catid=&impid=
If you have a floppy drive, this is easy just copy to a floppy. Then during the install WinXP says something to the effect of "Press F6 to install 3rd party or RAID drivers" hit <F6> and direct it to the drivers on the floppy.
You should now be able to complete your WinXP install.
If you don't have a floppy drive post back here and we'll try to see if we can get the drivers in there another way.
Thanks
Dave
Nov 21, 2008 | Dell Computers & Internet
How to use/add sata on my mobo?
You need to add a controller card for SATA. These are not expensive. One you might consider is this:
Vantec UGT-ST200 Serial ATA PCI Host Card
It costs about $25, and is available many places, including Tiger Direct, Fry's Electronics, and others. Here is a link to one on the Fry's website. Shop around, you might even find it somewhere else cheaper:
http://shop4.frys.com/product/4236634?site=sr:SEARCH:MAIN_RSLT_PG
Once you install the card in an empty PCI slot, you install a new SATA hard drive, and cable it to it. It should work fine with your existing PATA drive(s).
Cheers
Nov 13, 2008 | PC Chips M848ALU Motherboard
Upgrading to 2 GB Memory - only one DIMM recognized?
have you booted your computer into bios and see what it tells you there
Aug 19, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Installing xp freezes
If it will only boot in safe mode it means you have a driver conflict.
This is only a suggestion but try fresh reinstalling windows, with only basic xp drivers then install other drivers one at a time rebooting each time you do until you come across the faulty one. remove it or check its for xp not vista research net for correct one
Jul 17, 2008 | MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/...
PC Chips M863G Motherboard Logo
94 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
