Question about Dell Inspiron 1501 Notebook
Rundll error i have dell 1501 laptop...it was good n faster when i baught..but now it's so slow n i think there is rundll error in pc...so help me out what i do to solve this problem
  • wol2502157 Dec 18, 2008
    had same problem you need to restore computer to earlier time before this problem come up hope this helps
    Scholar:
  • 46 Answers
Well, unfortunately, as time goes on with any computer the hard drive accumulates gunk from mostly new programs and the internet. There are more start up things going on in the background, more spyware and malware that you can't see, you probably have a virus somewhere, and there's so many indexes and so much data fragmentation that it becomes slower than slow. All in all, it's your hard-drive's fault, nothing else on the lappy is to really blame.
If you have a rundll error, then that could be being caused if the file was removed by another program (most programs share .dll files.) during an uninstall, or for possible registry or even hard disk sector errors.
There's a few things I can suggest as more or less temporary fixes if the hard drive (physically) is not the problem.
1) Get something like AVG free (google it) and run a virus scan, along with getting Lavasoft Ad-Aware (which is also free and removes malware gunk). Also a program called Spybot, again free, will allow you to make changes to windows start up fairly easily. You can use that to turn off stuff that well, you never use (just don't turn off stuff with anything saying windows or system or you'll run into *very fixable* issues :P )
2) Another issue is Free disk space, this is important for defragmenting, bad sectors, page files, and seek times (so it need not plow through a bunch of addresses to get to a file you want) The advantage of free space is most noticable at 25% free, but is best (though not as noticeable) at 70%, by that point it doesn't get better. Here's how to do it.
2 a) Remove extra stuff, (if you're running XP) go to start, accessories, system tools, disk cleanup. And remove all the **** that's there. Also be sure to go a few tabs over (top of the window) and delete all the restore points (don't worry, it won't delete your very last one), this frees up a huge amount of space taken by windows to make disk images.
2 b) DEFRAG, it is important to do this if you never have before. Over time your hard drive begins looking like a horrible game of tetris, fix it up by going to (if you are running XP) start, accessories, system tools and disk defragmenter. This will give you a bit more free space while making your hard drive more organized, and a fair bit faster (I'd say 2-15% ranging).
2 c) Simply put stuff you don't use onto backup hard drives (where free space matters very little as opposed to the main drive of the computer) or delete it if it's never used. Games especially take up tons of free space, and since their files are typically loaded into ram and the pagefile anyways....it wouldn't be bad to move them to externals.
2 d) google Pagefile defrag, and you'll find a handy free utility for defragmenting the pagefile (since the normal defragmenter doesn't do it since it's actually using the pagefile for most of it's work). Helps organize.
The permanent solution for this though.....unfortunately, is to back up ALL your important data, format your hard-drive, and re-install your operating system. Starting from scratch is the permanent way to do this. However....
NOW, if your hard drive IS a problem, then we're going to have to do some other things.
If doing all of the above (Except the reinstall the OS part) didn't seem to do anything, then your hard-drive might be having some troubles (especially if it's making odd noises.) To test to see if it IS the hard drive, you need to go into your diagnostics. Usually pressing the Fn Key and the power key at the same time when the lappys been off for a while will get you there, just follow it's instructions to test your harddrive sectors for read write issues (known as bad sectors) if there are some....
The permanent solution, Get a new hard drive from your manufactuer. You can clone the hard drive using Norton Ghost (not free....) or another free application (just search cloning free into google), and that will give you an exact copy of what you have on the old hard drive to the new one.
The temporary solution (which I'm currently doing :P ) is to go into my computer, right click on your hard drive, click properties, go to tools, and run the scandisk application. Set it to automatically fix errors, and then when it asks you to reboot the lappy do so.
This will go and check your hard drive for bad sectors, then it will 'try' to read the data on one, and put it onto a new sector that's free (which is why free space is so important with bad sectors.) then it will mark the bad sector as unuseable, and after the procedure the lappy will reboot, and should work much better.
This can fix a lot of troubles....for some time, until the problems happen again (which knowing hard drives they will) and it can't be done constantly because eventually the drive is just on the brink of utter doom
Only proper cooling, or a new hard drive, can solve this kind of issue for good.
This was a long one :P But hope it helped.
Stay spicy, and happy lappying!! :)
Remember to rate!
Posted on Dec 18, 2008
What is rundll error on Dell Inspiron 1420?
I would uninstall AVG, it gets in the way and is not very good after running Advanced System Care from IOBIT. It is a freeware programme and will clean up the spurious stuff that gives you errors. Then install Microsoft Essentials as your anti virus programme. That is also free.
Jul 22, 2014 | Dell Computers & Internet
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
RUNDLL Error Message, Windows XP
Dear sir,
Welcome to Fixya.
Rundll error is observed when computer is attacked by viruses and spyware.I think your computer is infected by virus and spyware.You can remove the viruses and spyware by using good Antivirus software,but if you want to get rid of all errors permenantely, solution is format your pc and reinstall your operating system then install good antivirus.
I think it helps
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
I formatted my dell inspiron 1501 and returned it to factory new, but in a word processing program the type is slow to appear, almost like it's running in slow motion. It eventually appears, but it is...
OK if you returned to factory specs go to power settings switch from default to performance this eats more power but every program runs faster!!
i hope this helps you let me no.
Aug 01, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 1525 is running slow
resart the router and clean all temp files from internet explorer.
refix all connection to router.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Run dell error
Since this is such an old machine I would imagine there are a lot of unnecessary programs running in the background and starting with windows. I would say the quickest solution would be to back up any data you want to keep and then reformat and reinstall. If you do not wish to do that there are some other steps you can take. First go into the control panel and then add/remove programs. Go through the list and uninstall everything you don't need/want. Secondly, click start then click run and type in "msconfig" without the quotation marks. Click on the start up tab and uncheck everything you don't need to have starting with windows. I would also run your spyware/adware scanners and run your anti-virus. Lastly, I would defrag your hard drive.
Dec 17, 2008 | Dell Laptop InspironTM 1501 PC Notebook
Computer is sticking and slow
HI
All you need to do is to run an Anti-Spyware program on it. Normally it will make it go faster.
Also you might want to try to limit startup programs meaning to get the laptop to start the minimum programs possible.
You might want also to backup your personal files and scrap everything, do a fresh installation.
Hope it works fine
cheers
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Insperon 1501 freezes
This can be caused by hardware or software. Eliminate the hardware by running a diagnostic check. To do this, hold down the <FN> key and push the power button. If hardware checks out, you probably have a software, virius or spyware issue.
Oct 15, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
144 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
