Question about Iomega U.S. Power Supply Drive
Want to know polarity of Zip 100 DC power supply.
I have a non- Iomega power supply, but need to check that the polarity is right before using. The polarity is not marked i on the case. Anybody see it in the handbook - or can stick a meter on their power supply for me?
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Posted on Apr 21, 2009
Center pin is positive on my zip 250 dc power supply.
Posted on Jan 27, 2009
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Cannot open drive E on Iomega zip 100
Assuming you have connected the drive and then restarted the computer with the drive connected and powered on... if it is model 31714 (not the same as the picture no power supply is required - if power supply is required make sure unit is powered on prior to connecting)
First guess at your problem. Your disks are formatted for a operating system other than what you are using. (Mac formatted disks on a PC or the other way around)
If you don't know how the disks were formatted you could test this by letting it get to the "insert disk" and then trying to right click and see if you have a format option ... note this will erase all information on the disks.. you will likely need to long format
Second guess the drive is bad... have seen cases where the drive is bad. If you have another computer you can use try hooking the computer up to another computer and see if you get the same result.
Let me know if this does not work and specific model number and op system I might have more ideas. I can also point you to a replacement If I know more about your system.
Feb 20, 2015 | Iomega Zip 100MB (31714) External ZIP...
How do you get a disk to pop out of a iomega zip 100
Hello.
If your iomega drive is connected to your computer, open My Computer and right-click on the Zip disk drive icon and choose the option to eject.
If unsuccessful, or the drive is not connected to your computer, remove the disk manually. Look for a small hole or lever. If a small hole, use a straightened paper clip and push into the hole to remove the disk. If a lever, lift and pull backwards.
Hope this helps.
Jan 07, 2012 | Iomega ZIP 100 MB USB (32133) External ZIP...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega zip 100 external
hi
can you try reformatting that? it may readily upgrade itslef after reformatting it.
Jan 28, 2008 | Iomega ZIP 100 MB SCSI (10011) External...
Iomega U.S. Power Supply Drive Logo
647 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
