Question about Olympus DS-2 Digital Voice Recorder
I have facing an error while downloding that error was lack of sufficient buffer or queue was full. thx in advance.
  • Olympus Expert
  • 479 Answers
It would appear that the download location may have changed... check the download location and also check in removable devices for your device... call oly tech support 888-553-4448
Posted on Dec 18, 2008
What does queue mean, it comes up on movies ?
tcp/ip protocol uses a try to send one packet and then check if it got received ok
then it will send two packets and check
then it will send four packets and check
then it will send eight packets and check
you get the picture 8,16,32,64,128,256,512,1024,2048,4096, error ok lets resend one packet and check
so if no errors occur the packets sent increase rapidly. However if there is an error it goes back to one packet.
Now this is not really a problem if say you were downloading a file but if you are watching a time dependent streamed movie this might slow down to a point where the movie would stop . So the media player software buffers the data. It downloads a quantity into memory and then when the buffer is full it starts playing the movie. However if you get errors or a slow bandwidth of data it has to queue while it restores data into the now empty buffer memory and might sto pplaying the movie while it does this.
Jan 16, 2018 | Computers & Internet
Printer queue is full..... i cannot print, everytime i try to print i keep getting an error message. Priner Queue is full. i can print from my other computer. all the printers are connected via the...
most probably your network cable and or printer connection is tampered double check it, b'cause it won't be noticeable....
Trust me,
 i had the same experience
Aug 28, 2009 | Microsoft Windows XP Media Center Edition...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer canon mp 145 shock absorber is full
Plz check the buffer of ur printer if it contains any information select all and delete it and empty the printer queue.
thank u
Feb 27, 2009 | Canon MF8180C Color Laser MFC Printer
Printer goes into super slow motion when printing .pdf's
Try this --- Double click printer>Choose Printer from menu bar>Select Properties>Click Advanced Tab and make sure "Spool print documents and Start printing immedialety is selected>Click Apply Button.
Jan 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Please advice me as soon as uyou can ..thx
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Nov 09, 2008 | Computers & Internet
Label Printing stuck in queues
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Jul 21, 2008 | Zebra Z4M Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
May 05, 2008 | OKI MICROLINE 321 Elite Matrix Printer
Failed to Print error
clean the buffer before fiving print and then restart the system. If the problem occurs same then reinstall the printer driver and then try to print
May 05, 2008 | HP Deskjet 3915 InkJet Printer
Olympus DS-2 Digital Voice Recorder Logo
20 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
