Spray-arm falls off.
SOURCE: Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
SOURCE: tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
SOURCE: lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
SOURCE: not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
