Question about Visonik VB212PKG Car Audio Amplifier
Broken Potentiometer My vb212 has a broken/missing potentiometer on teh bass boost. I am not sure where I can find a schematic, or just the part. Can anyone help me? The part is called a C2K5X2. I think it is a 2k ohm pot. Any ideas?
    President:
  • 3,130 Answers
Contact the manufacturer in the owners manual or from where you purchased the unit from, ask them where or who the manufacturer is. Good Luck
Posted on Mar 28, 2007
SOURCE:
I need to get to the speed control to find a broken cord. I can get the appliance apart but cant get the speed control out.
A broken part ? or is only the potentiometer of the speed control thats damaged, but a wire that is broken ? without any force is hard to believe the spring element internally that moves along the carbon track of the potentiometer inbetween the speed control should have lost the contact pressure or only dirthy ?. where the resist for rpm mixing is lost. maybe marketing technical made to order it as a one-part assembly try contactspray in the potentiometer.
Aug 11, 2016 | Sunbeam Food Mixers
Fix for a missing volume control
For what piece of gear?!?!?!?!?!?!?
Dec 11, 2015 | Bass Music
Preamp changing
This is not program/software error. This is hardware error.
Damage is on the potentiometer. usually caused by a bad contact inside the potentiometer. The most common is the preamp-TYPE potentiometer.Faulty potentiometer can also occur in the other,
depending on what we hear, when (suddenly) the bass sound bigger or smaller, it mean that BASS potentiometer was bad.
Potentiometer must be replaced,because it can not be repaired or cleaned (except,you are experienced in parts repairing).. This is due to the potentiometer is to use a special type.
Jul 14, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Jan 04, 2013 | Cambridge Soundworks SWBE SoundWorks PC...
My bass drum stopped working. The module wont pick up any signal and ive tried everything short of replacing it. Not sure if its the wiring the module or the drum sensor itself.. Everything else works just...
Verify the module by connecting a different pad to the bass drum and see if you can trigger the bass drum sound. This would test the module. Now connect the bass to a different input and see if it will trigger that input. SOME of the triggers have a very small potentiometer in them. I have seen vibration break this pot loose rendering the unit inoperative. Also some people have pushed a screwdriver into the pot too hard and broken it off. Once you know it is the bass trigger, open the unit and look for damage. The sensor is usually a piezo disk. These can break away from their attachment. Reattach with contact cement after cleaning the residue.
Apr 14, 2011 | Alesis DM6 Performance Electronic Drumset...
There is a repetative clicking sound whenever I use the treble on my guitar. what is causing this?
Did you mean the treble control potentiometer (knob)?
This was posted as an amplifier problem, but since you mentioned that the use of the treble (button?) on the guitar is causing the clicking, i would have the treble potentiometer checked first.
It could have a loosely soldered or broken wire on any of the tabs, oxydized slider contacts, bad ground (negative) connnection, possibly dirt or damage on the resistive track inside the pot.
A broken wire can easily be resoldered, but if there is internal damage or oxydation, the potentiometer should be either cleaned or replaced.
In short words - it may be a faulty treble pot.
There are ways to disassemble and clean a potentiometer, but the difficulty of this task may vary and depends mostly on the type and build of the pot.
The other alternative is to have it replaced.
regards
Triarcuate
Sep 26, 2009 | Fender Hot Rod Deluxe Guitar Combo...
How to replace a potentiometer on a Hartke 3500 Bass Amplifier?
unplug unit and leave OFF. Unplugged, turn on for 1 minute to "drain" capacitors, then turn off. Remove cover. TAKE a DIGITAL PHOTO of the rear of the potentiometer. Mark the 3 wires with masking tape and a Sharpie marker. Take another photo. Cut wires as close as possible to the potentiometer. Remove the knob, then remove mounting nut/washer. Now, you need to figure out the value of the potentiometer. Using an ohm meter or multimeter, measure the resistance from one outside terminal to the other outside terminal. It should be a ready like 100K, (100,000) OHMS. It may also be marked on the unit as 10K, or something with a "K" suffix. Replace with a potentiometer of the same value -AND- make sure that it has an "Audio Taper" not a "Linear Taper". Mount the new potentiometer and reconnect the 3 wires in the same fashion as the phono. Strip 1/4 inch of insulation from the wire and wrap around each post of the unit per the photo. You should solder each wire, or worst case, tape securely until you can get someone to solder the wires. Replace cover. Plug in unit and perform "smoke test". If volume doesn't change at all, then center wire is in wrong place and wires are out of order. If volume is in reverse, swap the two outside wires only. You really should get a ham radio buddy or someone to do this work for you, as you could mess it up, but you are welcome to give it a try. You can buy the potentiomer from MCM Electronics, and possibly Radio Shack.
Sep 19, 2009 | Audio Players & Recorders
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
If all else fails and you cannot find the correct pot for it then you might try using two resistors for each "layer" of the pot (there are probably two sections)that add up to 2K ohm and solder them in as a permenant setting to replace the pot. Maybe choose a value like 1.5K for one resister and .5K for the other. This would set your volumn to about three quarters of full. It's not necesarily a good solution, but it will get your amp going again. P.S. It may be a 2.5 K pot with two sections. Good luck.
Apr 11, 2007 | Visonik VB212PKG Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
