What harddrive does a medion 7960 have in it IDE or sata.As we a bad one that needs to be replaced thanks in advance
  • 916 Answers
It could be either or loom inside and if the hard drive looks like it has pins sticking out on almost all of it. it is an ide drive. Sata will look similar but will most likely have a cable attached to it with a red end and will look like it has less pens than an IDE.
Posted on Dec 19, 2008
Skimatice for hard drive connections
Schematic
The eMachines T6532 uses an MSI MS-7207 motherboard.
Also known as the KN8GM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
[ http://www.newegg.com/product/product.aspx?Item=N82E16813130041 ]
The MSI motherboard has provisions for using, EITHER an
IDE (PATA) harddrive, or a SATA harddrive. (Or more than one)
Two different technologies.
I will explain both, using an IDE (PATA) harddrive,
OR;
Using a SATA harddrive;
On the MSI Support page above, click on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Language > English > 7.1MB > E7207v2.0.zip
Click on the blue E7207v2.0.zip
On the next page click on the country name nearest yours.
A small window will come up -
Opening E7207v2.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; Left-click in the small circle to the left of Save File.
Now go below in the small window, and click on OK
A small download window will come up. Allow the file to download ALL the way, then DOUBLE-click right on it.
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(7207v2.0(G52-M7207X5) next to the red Adobe PDF icon)
There is the Motherboard Manual
The MS-7207 has two IDE slots;
IDE 1, which is Yellow in color, and close to the outside edge of the motherboard.
Should have IDE 1 silkscreened on the motherboard, below it.
IDE 2 is Yellow in color also, and right next to IDE 1.
(IDE 2 is in-between IDE 1 and the Ram Memory slots.
The Purple, Slot 4, ram memory slot to be specific. {DIMM 4 )
IDE 1 is used for an IDE harddrive.
IDE 2 is used for an IDE optical drive.
TWO IDE harddrives can be put on a single flat ribbon IDE cable,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
NOTE that there are two styles of IDE flat ribbon cables;
40-wire cable,
OR;
80-wire cable.
BOTH have 40 socket holes in their connectors.
(ONLY 39 are used, so one hole May, or May Not be blocked off)
How to connect to a 40-wire IDE cable, or an 80-wire IDE cable,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
An IDE cable usually has a Locating Lug on it's connectors, in the middle of the connector; and on one side,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Here you see the Locating Lug as being two separate 'ridges'.
Some styles the Locating Lug is single block.
The motherboard connector has a matching Cutout on one side.
The Locating Lug lines up with the cutout when installing the cable.
The Harddrive, and optical drive (CD/DVD drive), will have a cutout on their circuit boards.
There are 40-pins. (Only 39 are used if so)
One of them is the number 1 pin.
The IDE cables are plugged into the motherboard, with number 1 pin lining up with number 1 wire, in the IDE cable.
Same when the IDE cable is plugged into a Harddrive, or optical drive.
IF, there is no Locating Lug on the IDE cable;
Look for the faint RED stripe, on the side of the IDE cable.
Number 1 wire is on the same side, as the faint Red stripe.
When plugging into a motherboard, Number 1 pin is on the Bottom.
The faint red stripe on the cable, goes towards the BOTTOM of the motherboard.
(Motherboard installed in computer case)
When plugging into a Harddrive, or optical drive; the faint red stripe ALWAYS goes toward the power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
This shows you the Back of an IDE (PATA) harddrive, and the power cable used for it.
If -> No Locating Lug on IDE cable, the faint Red stripe goes towards the power cable.
This is a 4-pin standard Peripheral power cable.
Note when installing the rounded corners ALWAYS goes UP.
[This power cable is frequently, and erroneously; referred to as a 'Molex' power cable.
Molex was just the first manufacturer of the power cable CONNECTOR. Name STUCK.
Kind of like calling an adjustable open-end wrench, a 'Crescent wrench ]
A SATA power cable is used for a SATA harddrive, or SATA optical drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
There is an L-shape in the SATA power cable's connector.
It matches an L-shape on the Harddrive, or optical drive.
Between a SATA power cable's connector, and a SATA data cable's connector; a SATA power cable connector is the LARGER of the two.
A SATA power cable has 15-contact pins.
A SATA data cable has 7-contact pins.
A SATA power cable's connector may have a LOCK on it.
Usually a Tab, or 'bulb' type affair.
It is pressed down with the thumb when installing, or removing the SATA power cable.
This is a general example of a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
Now you can see the L-shaped opening a little better, that both the SATA data cable have, and the SATA power cable, has.
In the photo the SATA data cable's connector, is a 90 degree bent Elbow.
This style of connector is usually used on the Harddrive, or on the optical drive.
A Straight connector style is usually used for the Motherboard.
However, you can use a SATA data cable, that has a Straight connector on both ends.
Looking at your motherboard, installed in a computer case; there are 2 SATA connectors on the motherboard.
(CAN, be up to FOUR)
I see one motherboard reference where they (2) are Orange in color, (Newegg), and the motherboard manual shows them (2) to be Purple in color.
They are located towards the Bottom/Right corner of the motherboard.
Above the CMOS battery.
The SATA connector that is closest to the Outside edge of the motherboard, is SATA1 (SATA 1)
The Harddrive plugs into SATA 1.
An optical drive that is SATA, will plug into the SATA2 connector.
To the Left of the SATA1 connector.
KNOW THIS;
DOES NOT MATTER, which SATA connector you plug the Harddrive, or optical drive; into.
The beauty of SATA, is that you can plug the Harddrive or optical drive into ANY SATA connector, (On ANY motherboard), and BIOS will find those devices.
BIOS looks FIRST, to see which drive has the Operating System on it. (Windows)
THAT, is the Harddrive.
After finding the drive with the O/S on it, then BIOS will find all the other drives. Removable, or not.
So there you have it. A lot of reading.
You need a power cable, and a data cable to the Harddrive.
Same thing for the optical drive/s.
To have me clarify anything I have stated above, please post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 15, 2013 | E-Machines T6532 PC Desktop
Find socket for hard drive
HP part number 5188-5473 brings up the Asus A8N-LA motherboard, made especially for HP,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00647121#N413
The rest of the number/letters do me no good.
I will elate some information based on the above, and see if it does you any good;
1) The Asus A8N-LA has connectors for two types of Harddrives;
A) IDE. Also known as PATA.
This type of Harddrive uses a flat ribbon IDE(PATA) data cable,
http://en.wikipedia.org/wiki/File:Nappe.svg
Another look,
(The Asus name probably won't be on it. These two IDE data cables just happen to be made by Asus )
The connectors on each end have 40 socket holes. One socket hole will be blocked off. (Or should be) ONLY 39 socket holes are used.
A look at the connector on the motherboard;
http://en.wikipedia.org/wiki/File:ATA_on_mainboard.jpg
Looking at the motherboard illustration, look at the Bottom/Right corner. There are two IDE connectors. They are marked as IDE 1, and IDE 2.
Scrolling down a little bit to the motherboard photo, you will see IDE 1 connector is Black in color, and IDE 2 is Blue in color.
The IDE (PATA) harddrive's data cable goes to IDE 1.
Optical drive/s (CD/DVD drive) goes to IDE 2.
This is the type of power cable from the Power Supply, that goes to an IDE (PATA) harddrive,
NOTE*
There is usually a square, or rectangle, or two bumps; used on the IDE ribbon cable connector, to line up with the connector on the motherboard, or harddrive, or optical drive.
It is called a Locating Lug.
This particular IDE data cable connector, has two raised bumps, for a Locating Lug.
It lines up with a Cutout in the motherboard's connector, or the harddrive's connector, or the optical drive's connector.
IF, there is NO Locating Lug, use the faint Red stripe on the side of the IDE data cable.
The red stripe is on the same side as Number 1 wire.
Number 1 wire goes to number 1 pin.
On a harddrive, or optical drive, number 1 pin is ALWAYS closest to the power cable connection,
Looking at the photo number 1 pin is on the Right side. It is closest to where the 4-pin Peripheral power cable plugs in.
B) SATA:
Looking at the motherboard photo, the Yellow, and Blue, and Black, and White connectors; to the left of the Blue IDE connector, and Black IDE connector; are SATA connectors.
SATA 1 is Black. This is where the SATA harddrive's data cable, is supposed to plug in.
The BEAUTY of SATA though, is that you can plug the harddrive into ANY of those SATA connectors on the motherboard, and BIOS will find the harddrive. (Or any other peripheral device)
An example of a SATA data cable, and it's connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The red SATA connector shown below the SATA cable example, is just a different style of SATA motherboard connector; than what your motherboard uses.
Note the L-shaped opening in the SATA data cable's connector.
Lines up with the L shape on the motherboard connector, or harddrive connector, or optical drive connector.
Most SATA data cable connectors, also have a Lock on them.
Sometimes it's a Lock you can easily see.
Most times, it is a small depression you depress with your thumbnail, or a little 'bulb' you depress.
Depress/unlock to plug the cable in, or remove the cable.
The 90 degree angle connector end, (As shown), plugs into the harddrive, or optical drive. The Straight connector end plugs into the motherboard.
This is an example of a SATA power cable,
Between it, and the SATA data cable connector, it is the larger of the two.
SATA power cable connector has 15-pins.
SATA data cable connector has 7-pins.
Also note the rectangular depression on the SATA power cable's connector. That is where you depress to unlock the connector.
The SATA power cable's connector also has an L-shaped opening.
2) IF, you are trying to hook up a laptop harddrive to this motherboard, you need to determine if the laptop harddrive is an IDE (PATA) type, or a SATA type.
How?
Easy.
There is a label on the laptop harddrive. It has the manufacturer code on it. Type the number/letters in your browser search bar, and click on the search icon. (Magnifying Glass)
Now purchase an external enclosure.
The external enclosure opens up, and the laptop harddrive goes inside, and plugs into an interface.
Close the external enclosure, and plug it's USB cable into any available, open USB port on your computer.
It will be a 2.5 external enclosure.
Harddrive's are measured across their width.
A desktop harddrive is 3.5 inches across in width.
A laptop harddive is 2.5.
Example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Regards,
joecoolvette
Jan 28, 2013 | HP Compaq Motherboard
Hi, I have destop[ dell pentium R 4 cpu 3 GHz 1.99 GB of ram and 40 GB rom . I want to now if can change the hard disk and put another of 160 GB. tanks you carlos.
A) If you have the Restoration Disk (CD), or a full installation disk of the Windows operating system, the answer is yes.
B) If you have an image backup program, such as Norton Ghost, Acronis True Image, or DriveImage XML, for example, the answer is yes.
The Windows operating system is copied over to the new harddrive.
It would be easier, and more cost effective to just install the 160GB harddrive as a Slave drive.
I don't know if your harddrive is an IDE (PATA) unit, or a SATA unit.
Here is more information on installing either an IDE harddrive, or a SATA harddrive, as a Slave drive in a desktop computer,
1) IDE {PATA} harddrive:
http://www.youtube.com/watch?v=4inX3nC6M1E
1A) http://www.youtube.com/watch?v=OMTOgt3UiB4
2) SATA harddrive:
http://www.youtube.com/watch?v=kCgFYNLzn18&NR=1
IDE, also known as PATA is the older style of technology.
SATA is the newer style.
(Parallel ATA
Serial ATA )
The beauty of SATA is not only the faster speed, but if you connect a SATA cable (Data cable) to ANY SATA connector on the motherboard, BIOS will find the device.
BIOS (Basic Input/Output System) will find the harddrive with the operating system on it, first.
Then it will recognize that you have a second SATA harddrive also.
(BIOS looks at both SATA harddrives.
When it finds the one with the operating system on it, BIOS will disregard the other SATA harddrive)
http://www.youtube.com/watch?v=ScqDZZeFK9I
Regards,
joecoolvette
Jul 17, 2011 | Dell Computers & Internet
I need to locate a mother board for a firelite model #USBFLB40-C any suggestion? Or where can I get a new USB power data plug soldered on the old board? Thank you.
Yes I would take the Harddrive out of the SmartDisk FireLite external harddrive, and install it into an economical external enclosure.
Looking up reviews just now I know that it's a laptop sized harddrive that's inside.
(The Harddrive inside is 2.5 inches across in width. 2-1/2 inches)
I don't know however if it is an IDE or SATA unit.
But you will know once you get the case open, and view the Harddrive inside.
One example of a 2.5 IDE external enclosure,
One example of a 2.5 SATA external enclosure,
One example of an external enclosure that will support IDE or SATA harddrives that are 2.5,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Regards,
joecoolvette
Jul 04, 2011 | SmartDisk FireLite 40 GB Hard Drive
Dear Sirs, I'm from Holland and did use for three years now a Medion MD96418 to full satisfactory operation sofar. Last weekend suddenly a nasty smell got around the laptop and the charger did not charge...
F.Wolf, from the diagnoses given by you, the Medion laptop could have just sustained a Power Circuit Board damage, or it may be worse, and could be the motherboard.
The only way to find out is to open the laptop, (ALL power removed. AC adapter and Battery), and;
1) Physically inspect for visual damage to the Power Circuit Board, and the motherboard.
Not a very good diagnoses technique other than for apparent damage.
2) Buy, and install a Power Circuit Board.
3) Next in line is to replace the motherboard.
Due to the cost of just the Power Circuit Board alone, I feel this is redundant.
Also borderline redundancy, due to I hate just changing out parts to see if it cures the problem.
Quick search on the internet for a Power Circuit Board, for the Medion MD96418,
http://www.mattotechinternational.nl/E_frame.html?http://www.mattotechinternational.nl/Powerboard+Medion+MD96418++E_art_197.html
(As you can see the DC Power Jack is mounted on the Power Circuit Board, and the Power Circuit Board is a separate circuit board from the motherboard.
It could BE just a bad Power Circuit Board)
For the Power Circuit Board cost alone, I feel you're well on your way towards the purchase of a decent used laptop.
Which brings us to removing the Harddrive, installing it in a decent, affordable external enclosure, and obtaining the information off of the drive.
I haven't repaired a Medion MD94600 series of Notebook PC.
I can't find at present a Service Manual online to give to you for disassembling the laptop, nor can I find the specifications.
Therefore I cannot tell you if your need a 2.5 IDE (PATA) external enclosure, or a 2.5 SATA external enclosure.
( A laptop harddrive is 2 and 1/2 inches across in Width.
2.5
63.5 Millimeters)
The drive will have IDE or SATA marked on it, or you can use the Model Number online to look up the specifications.
This is one example of a decent (IMHO) 2.5 IDE external enclosure, (PATA)
This is one example of a decent 2.5 SATA external enclosure,
[ You may find information here, to help in disassembly to replace the Power Circuit Board, should this be the direction you wish to take,
http://repair4laptop.org/disassembly_medion.html ]
Regards,
joecoolvette
Dec 02, 2010 | Computers & Internet
I have a acer aspire t180 desktop with a 250gb hitachi scsi (ide) hd. I would like to know which hard drives are compatible so that I can exchange it. thanks
It's a SATA harddrive, not SCSI.
Serial ATA
Acer Support > Aspire T180 > Specifications >
http://www.acersupport.com/acerpanam/desktop/0000/Acer/AspireT180/AspireT180sp2.shtml
Will use up to a 400GB SATA harddrive according to Acer.
IDE stands for Integrated Drive Electronics.
Another name is PATA.
Parallel ATA
Used to distinguish between IDE and SATA.
1) http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
2) http://en.wikipedia.org/wiki/Serial_ATA
3) http://en.wikipedia.org/wiki/SCSI
Exchange it?
Your harddrive has the Operating System on it.
A new harddrive will not have an O/S on it.
(Windows XP is an example of an O/S)
It would be much easier to install the harddrive you wish into an external enclosure, and plug the external enclosure's USB cable into your T180.
One example of a desktop size harddrive SATA external enclosure,
(3.5 inch SATA external enclosure.
3 and 1/2 inches across in width, for a desktop harddrive.
Laptop HD's are 2.5)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Jun 18, 2010 | Acer Aspire™ T180 PC Desktop
I have a samsung hmo 6011 harddrive can i replace it with a samsung f3 sata 11 drive
If the samsung hmo 6011 harddrive (couldn't find that model) is SATA then yes, and SATA drive will work. The only thing to make sure is that you get the right size; for a laptop or PC. If the samsung hmo 6011 harddrive is IDE (has pins) then no, they cannot directly replace with a SATA.
Here is a good comparison picture http://www.laptopparts101.com/wp-content/uploads/2008/12/sata-ide-laptop-hard-drive.jpg
Feb 03, 2010 | Computers & Internet
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Jul 13, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
