My HP1906 Monitor is asleep ... How do I wake it up.
This monitor is new to my use and I do not have any instructions available
    Champion:
  • 293 Answers
Hi...there,
Well, new could be defective too... You're probably got a busted backlight inverter problems... Send it back for repaired. Happy Holidays!
Posted on Dec 18, 2008
Monitor has power to it and signal from computer but is asleep and wont wake back up
Is it showing any flashing indicator lights?If not:
....You have to try a different vga cable if it is not built into the monitor, and make sure the pc will drive a known working monitor ok from the same port. If the pc is ok and there are no fault lights showing I would suspect the vga cable
Jan 25, 2011 | Computers & Internet
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
After a while the monitor will fall asleep and wont go back on. I have to restart the computer in order for it to use the computer again and it'll repeat this over and over.
Try looking in the monitor setup menus, and changing the way that it detects an idle condition. Also check your video card to see how it is telling the monitor to goto sleep. Some use suppressed baseband, others use (very common) blanking. Change video card, may help monitor as well.
Nov 02, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Same as the guy above me
You have a power supply in the monitor that powers the fluorescent tubes. That circuit board can be ordered on eBay for your model and replaced. Helpz, yes?
Jul 05, 2009 | Hannstar I-Inc TW-191D Monitor
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Monitor won't stay asleep
I am not familure with that type of monitor however I found through being a IT tech that some monitors have a setting that allows windows to control sleep and wake commands. You might want to take a look at your monitor controls usually located in front of the monitor. This may solve your problem.
Jan 24, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
507 people viewed this question
Alun Cox
David Payne
David Payne
