Question about Mitsubishi WS-65413 65" Rear Projection Television
Rolling screen the picture comes on clear for 1-2 min then starts to roll horizontaly fast shut tv off wait 30 min turn on works 1-2 min thein same thing this happens with ant inputs a-b and video inputs "yellow white red" but my componet hook up plays perfect never messes up.
  • flickerornot Dec 17, 2007
    I have the Mitsubishi ws-65807. The comcast and the xbox 360 works fine but when I plug any other componets in the screen flickers horizontally on any of the inputs I choose, I have tried plugging differrent DVD players and other game consoles that have worked in past.
    I have also tried swapping a ps3 into the input that works for the xbox and the results are the xbox works but the ps3 does the horizontal flicker.
    Is there something i need to re-set?
    President:
  • 3,130 Answers
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Posted on Mar 28, 2007
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Apr 04, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Mar 11, 2007 | Toshiba 36AF61 36" TV
Mitsubishi WS-65413 65" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
