Question about Canon BJC 2110 InkJet Printer
Printer cartridges go to center of printer and then nother.
Cannon BJC 3220 is selecyed to print my documents and then, the printer cartridges proceed to go to the center of the page and then the printer stops.
  • 2 more comments
  • bon319 Dec 18, 2008
    The printer gets ready to print by placing the cartridge in the center of printer; then it makes the noise that the paper will be dropped into place and shuts down.
    My BJC-2110 Cannon printer is not taking the command to print from my computer. The cartridge moves to the center of the printer and then it printer stops.
    The Cannon printer I am using is BJC 2110. The command to print reaches my printer and the ink cartridge moves to the center of my printer; then nothing else happens.
  • agusk Apr 04, 2009
    Same as mine, the cartridge stops at the center after initialisation ( move left and right, cleaning, etc.). any idea how to solve ?.....
    thanks
  • Canon Master
  • 1,879 Answers
What does your ink level monitor tells/shows you?
Posted on Dec 18, 2008
  • 162 Answers
Check you inke levels first
    President:
  • 2,110 Answers
Check ur cartrdge having ink or not...It might be empty..
    Sergeant:
    Champion:
  • 247 Answers
Have you tried to align to cartridges? try shutting the printer off for a little while and then turn it on and see if it still does it.
  • Thomas Dec 18, 2008
    that sounds like the drives could be mesed up i would reinstall them and then check the ink level in the cartridges. it might be some kin of auto sensor letting you know they are out of ink.
    thanks Tom
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls clean the encoder strip. This would be the clear narrow but long plastic strip with bar like markings similar to barcodes. The markings and the clear space in between tells the print heads its position. it there is a smear or ink mark, the head would assume that it has reach the end and therefore stop. it would be similar to the image below.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 18, 2008
    A couple of ideas to explore/consider:
    • Pls check on powering up the printer, does the head goes straight right to fully left then back right again?
    • On about to print first page, isn't the standard movement fully left (from rest/right) before center?
    • shutting down would be protective mode, the printer has detected an error.
    • Pls check for any blockage, foreign materials, paper clip, stapler and others of the sort.
    • try cleaning the inside, a can of compressed air sprayed with moderation would help remove dust and particles from hard to reach nooks and crannies.
    Cheers.
Where can I find carteidge holders for BJC-80 Cannon printer
Hello JBM,
Please press the cartridge button and the cartridge holder moves to the center. Gently press and pull the front cover toward you. Press the green tab on the front left edge of the BJ Cartridge cartridge holder. This releases the BJ cartridge. Lift the entire cartridge out of the printer. If installing a new BJ cartridge, take it out of its protective packaging. Peel off the protective foil, and lift the cartridge out. Lift off the orange cap from the print head. Then remove the orange tape.
Jun 28, 2011 | Canon BJC 80 InkJet Printer
Printer not able to print?
Printer Keeps flashing green light
Mar 31, 2010 | Canon BJC 250 InkJet Printer
Problems with Canon BJC S400 - will not print ink on documents even though I just changed the ink cartridge
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | Canon BJC S400 / CanoScan N650U InkJet...
I have a cannon printer bjc 2100. It is printing
After replacing ink cartridges, you generally have to perform an alignment routine. On some printers, they have an automatic alignment function, others require the printing out of one or two sheets of paper and a possible adjustment via the service section of your printer software. If this isn't done, you can have an output similar to that you describe.
Oct 24, 2009 | Office Equipment & Supplies
I have a canon BJC-3000. Do I have to replace my
Just select "grayscale printing" in the properties box for the printer. Open a document to print, when you get the "printer set up" box, select "properties, and look for a check box that says "grayscale printing" and check it. You will now print in B&W
Aug 24, 2009 | Office Equipment & Supplies
Canon bjc-4300 cartridge insists on staying in middleofprintfield
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Canon BJC 4300 InkJet Printer
Vista + cannon BJC 250 = error
Go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6729
and try the XP driver. If this doesn't work, you may not be able to interface this printer to Vista.
Let me know if this works.
May 30, 2008 | Canon BJC 250 InkJet Printer
Parts
The BJC-55 takes 2 different types of print heads. And also a scanner head, that snaps into the same place and turns the printer into a scanner.
One print head is a Canon BC-11E. It has 2 ink tanks in it. 1 black and 1 tri-color. It prints in full color or black
The other print head is a BC-10. It prints only in black. But the ink yank holds 4 times the black ink of the BC-11E. It is very popular with business travelers who print only documents. The printer works about twice as fast with it. And replacing ink is a lot cheaper.
The scan head is called an IS-12.
Prices range from 40 to 60 dollars in supply stores ( Staples, etc)
Ebay is a good place to look for them
Oct 27, 2007 | Apple Canon BJC 55 InkJet Printer
Bjc 2100 printing errors
Replace the printing head. It's a known problem for BJC 2100.
Jul 26, 2007 | Canon BJC 2100 InkJet Printer
Canon BJC 2110 InkJet Printer Logo
115 people viewed this question
old marine
old marine
