Question about JVC DD-8 System
Network connection problem
4 Suggested Answers
SOURCE: JVC TH-S3
try setting tv to s-in it should be in the menu
Posted on Feb 17, 2008
  • 1894 Answers
SOURCE: home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Posted on Aug 22, 2008
  • 34 Answers
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 09, 2008
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
Tip
Enable WZC (Wireless Zero Configuration) and connect to wireless network on...
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
7. Highlight thee SSID from the list that you want to connect to.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
on Feb 13, 2010 | Microsoft Windows XP Professional SP2
How to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
I am connected to wired network and TV reckognizes it but smartTV isn't working(connecting.....forever)
Check your Home Network first.
• If one computer can access your router configuration, check if the
TV is properly configured.
• If one of your computer can connect to your TV or Vice versa
then you have successfully configured the TV.
Refer to the web site of your model of TV for more details.
Jul 27, 2012 | Televison & Video
Cant connect with linksys broandband with my other pc how to reset my network key?
1. open wireless router page, by typing the IP address of router in address bar of Internet Explorer.
2. Once the router page gets open, on left hand side you would be able to view a link which says "Configure".
3. After clicking on "Configure" button, you would be able to view wireless.
4. After clickin you wireless you would be able to view WEP, WPA keys option.
5. You need to select one of it and then type the new network key, if you select WPA key please note that it should be in 8-64 characters/numbers.
6. Click on OK and then try to connect your computer wirelessly.
Jul 18, 2010 | Linksys Wireless-G WRT54G Router
Cant connect to our network
Hi, please perform the below task to configure settings on your computer:
1. Right click on My Computer icon and go to Manage. 2. Go to Services then go to Service and Applications. 3. Double click on Wireless Zero Configuration. 4. Change the Start Up Type to Automatic and click on Apply 5. Click on Start and press OK to close the window. 6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 7. Right-click on the wireless Network Connection icon and select 'Properties'. 8. Go to the 'Wireless Networks' tab . 9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 2. Right-click on the wireless Network Connection icon and select 'Properties'. 3. Click on the 'wireless network' tab. 4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK. 5. Right-click on the wireless Network Connection icon and select 'View Available Networks'. 6. Look for the SSID (aka Network Name) of the Wireless router or access point. 4. Highlight thee SSID from the list that you want to connect to. 5. Type the security Key here and click on the 'Connect' button. 6. You should have successfully established a wireless network connection.
Hope this allows you to resolve the issue.
Regards
Anand Gupta
Apr 29, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
JVC DD-8 System Logo
76 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
