Question about Acer IBM DNES 309170 (91.AB032.008) Hard Drive
RE DNES 309170 E182115S IBM HDD
I have got OCE750C software installed in SCSI DNES 309170 E182115S ibm harddisk. However the harddisk cannot read the software. Also I installed a new harddisk and installed software, but the software cannot be read from it. Kindly inform whether their is problem in harddisk or their is problem in server. The harddisk is also making noise. How to format and reinstall the software please guide. kishoreom@rediffmail.com
  • Anonymous Dec 18, 2008
    When I am trying to play Winamp, I am getting one message that the sound divise is not installed. I want to get operate the Winamp and Media player.
3 Suggested Answers
iqbal_del
  • 655 Answers
SOURCE: problem soundcard driver of ibm think centre p4
titoo,
The driver you need, depends on your soundcard manufacturer.
  • Goto IBM site, find details for your model and try to download driver from that site as per your Operating System.
Thanks
Iqbal
Posted on May 18, 2008
  • 153 Answers
SOURCE: About SCSI
Replace the hard drive with a drive that is the same type and the same size, or larger. It will rebuild itself.
By same type I mean that the connector on the back of the drive and the speed of the drive interface must be the same. If the new drive spins at a different rate it will not create a problem, except that if it is slower it will make read/writes slower. If it is larger it will only use part of its capacity, matching the capacity of the other drives.
Note that if you were to replace all drives with larger drives (one at a time) the capacity of the entire array would be the same as the original. If you want a larger array it must be built from the start with that larger capacity.
Take out the bad drive. If you can get the exact same drive, do it, otherwise look it up on the manufacturers web site to find out size and type.
While there are a few possible RAID configurations that you could be using on that server, the chances are overwhelming that it is RAID level 5 that you are using. This RAID level is tolerant of a single drive failure. If you lose another drive before your new drive rebuilds your data will be lost. Hopefully you have a backup.
RAID 5 stripes the data and the parity data across all available drives and when a drive fails, the missing data is rebuilt on the fly from the parity data. When a replacement drive is installed the parity data is used to rebuild the data that belongs on that drive. The advantages of RAID 5 are fault tolerance (of a single drive) and speed because each drive only has to provide or write its portion of the total data being accessed or written.
Posted on May 26, 2009
What is the maximum Storage space that a IBM x226 Server can be scaled
6 x 300GB (largest available U320 SCSI HDD Capacity) = 1800 GB
Mar 26, 2015 | IBM Computers & Internet
Boot problem with IBM xseries 306 - SCSI Drive and SATA drive os is on scsi drive and wont boot if sata is installed. how do i force machine to skip sata drive
I think first u disconnect ur all HDD to server. then u enable ur booting HDD or operating HDD...and setup again....
Another way: If u have original windows ..u can use windows recovery disk ...then recover ur missing file(kernel).
Thanks
Dec 21, 2010 | IBM eServer xSeries 306
I loost a hard drive, my computer say the hard
you'll have to purchase an new IDE hard drive, although you will loose all of your data from your old one.
Jun 17, 2010 | Acer IBM DNES 309170 (91.AB032.008) Hard...
What kind of hard drives do acers have in them. Also if I had one without an acer laptop to put it how would i get the information off of it. without having another acer laptop, is there something i can...
You can buy a hard drive enclosure,with USB connection.
Then fit the harddrive in it.
Then connect it to any Windows computer and transfer the info.
Just make sure that the hard drive you are transfering to is large enough and have enough space to accomodate the info.
Just go to this site with www.belarc.com. the laptop you want to ascertain about the hard drive type
Download thesystem analyser,and it will give you a readout om just about avery hardwarea and software on the laptop.
In additio to othe ruseful info.
Jan 22, 2010 | Acer IBM DNES 309170 (91.AB032.008) Hard...
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
I cannot install windows xp in ibm x3400,the system is currently raid5,it shows message hard disk not detected. thanks
I believe your HDD must be a SCSI disk whose drivers might have come along with the HDD.While installing XP it gives an option to install third party drivers for your HDD, Hopefully after that it would start detecting
Aug 26, 2009 | IBM x3400 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Acer IBM DNES 309170 (91.AB032.008) Hard Drive Logo
204 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
