Question about Acer Aspire 3000 Notebook
Notebook Isn't Working
I have an Acer Aspire 3000 Series Notebook, and now whenever I try to log onto it, it automatically logs me off a few seconds later. But for the few seconds I'm on, there are no icons or anything else showing. A friend told me to try putting it into "Safe Mode" but I don't know how to.
  • Alexandra Godas Mar 28, 2007
    Joat...
    I tried doing what you said (I may not be doing it right). After I put it into Safe Mode and it takes me to the Log In Screen, should I go ahead and Log On, or should I restart it?
    How can I do a system restore?
    Scholar:
  • 121 Answers
When starting the computer tap the F8 key repeatedly. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again. Ensure that the Safe mode option is selected. Press Enter. The computer then begins to start in Safe mode. When you are finished with all troubleshooting, close all programs and restart the computer as you normally would. Or you could do a system restore to a earlier date when your computer was working fine.
Posted on Mar 28, 2007
3 Suggested Answers
SOURCE:
Shayna
  • 64 Answers
SOURCE: Notebook Isn't Working 2
Try logging in as another user. Sometimes there can be a critical error generated in windows that is related to a certain process or user specific setting.
ImWireless
  • 113 Answers
SOURCE: Trouble With Acer Aspire Series 3000
- Did you make any recent software or hardware changes? - It might be a adware or spyware issue - The best thing we can do at this point of time is : System Restore - Boot the system using 'safe mode with command prompt' option - And execute : '%systemroot%\system32\restore\rstrui.exe' ; where %systemroot% is the windows folder good luck
Posted on Mar 29, 2007
My Acer 3000 Laptop seems to be 'frozen' in 'preparing to hibernate' screen, how can I fix this please?
Drain Flee power
Steps to do
· Disconnect AC adapter,
· Remove Battery
· Press and hold power button for 30 seconds.
· Reconnect adapter and battery
· Start your pc and go to safe mode and check power settings.
· Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 09, 2010 | Acer Aspire 3000 Notebook
Tip
How to reset Acer Aspire 5315 notebook to factory setting
There are two ways to reset the Acer Aspire 5315 notebook to factory setting which also means to reset it to the original setting.
The first way to reset the Acer Aspire 5315 to factory setting:
  1. Log-in as Administrator (if you have more that one account on your notebook).
  2. Go to Start.
  3. Select All Programs.
  4. Then select Accessories.
  5. Press System Tools.
  6. After that, press on System Restore.
  7. A page will appear, press Restore My Computer.
  8. Next, press next to continue.
  9. A message will appear, press Ok.
  10. Press next to confirm the restore point.
  11. The system will be restored.
  12. Restart the notebook.
The second way to reset the Acer Aspire 5315 to factory setting.
  1. Turn on the Acer notebook.
  2. Wait for a few seconds until you see the 'startup' process appears on the screen.
  3. As soon as you the 'startup' on the screen, press Alt+F10 for about five times.
  4. This will set the notebook automatically to factory setting.
**Try these steps at your own risk. Make sure to save on a Pen drive or USB Flash Drive any important documents/files before resetting your notebook.
on Apr 22, 2010 | Acer Aspire 5315 Notebook
I forgot my password to log onto itunes
This is what to do if you can unscrew your laptop gently and look for the CMOS battery on the board of your laptop and then remove it for a few seconds and then replace it back then on your system if that persist then until you reload your system ok
Mar 06, 2010 | Acer Aspire 4720 Notebook
Log in problem..
when welcome screen shows up, click and hold (CTRL + ALT) then while pressing them press DEL twice, this will switch to classic view.
type in
User Name: Administrator
Password: leave empty
the press Enter
you should log in fine, then go to control panel ----> user accounts
and delete the current user accounts and make a new one for you.
this should be it. make sure your antivirus is up to date whenever using the internet
Let me know if this helped, good luck :)
Dec 26, 2008 | Acer Aspire 4315 Notebook
Aspire 3000
Thats called the blue screen of death. Do you hear any clicking from the hard drive at all? Have you gotten it wet? Have you dropped it? This most likely is a result of hardware failure but can also be caused by malware. Do you have another computer with CD burning capability? You could burn a few hardware tests onto cds and test the memory and the hard drive. google memtest86 for a memory test and DFT or Drive Fitness Test for a hard drive test utility. These have to be booted to by the laptop.
Dec 07, 2008 | Acer Aspire 3000 Notebook
Notebook Keyboard will not work and neither does the touch pad for the mouse
well..maybe..could be the cables under the keyboard have loosened, or it would be a mother board issue then
Oct 09, 2008 | Acer Aspire 3000 Notebook
ACER ASPIRE 3000/5000 SERIES LAPTOP
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Thanks and dont forget to rate!!!!!!!!
Jun 04, 2008 | Acer Aspire 3000 Notebook
My Acer Laptop can be ON but the Desktop does not open.
it's look like your windows is corrupt.
I suggest you to go to safe mode, safe/backup your data and then reload the operating system.
May 18, 2008 | Acer Aspire 3000 Notebook
Mar 29, 2007 | Acer Aspire 3000 Notebook
Mar 28, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
