Question about Canon NP 6050 Copier
Canon np6050 blank copy
  • Canon Expert
  • 1,326 Answers
Dose the scanning lamp come "ON" when you make a copy. If it will not come "ON" your scanning Lamp is blown and needs to be replaced. When the scanner lamp blows you will get blank copies..
Posted on Dec 19, 2008
    President:
  • Canon Master
  • 990 Answers
Dear sir; On the top of the drum, there have a about 1" square plastic, just pull it out inside got to have a hairlike wire check very carefully, I believe the wire is broken, replace it. and let me know if you need more help, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
4 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: dark horizontal line on canon np6050 copy
Did you try to run the wire cleaning funcation in the add. funcation mode? It could be that a wire cleaner got stuck in that spot and if you Run Wire Clean it may move it bake to Home Position and out of the way... Good Luck
Posted on Sep 20, 2008
Cogz
  • 1326 Answers
SOURCE: NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Posted on Dec 13, 2008
  • 170 Answers
SOURCE: my canon np6050 xerox machine doing darker copy .
just clean the optics mirror to clean those mirror remove the 2 screw in right portion of the machine the 2 screw is the lock of the metal plate in the right end portion of the platten glass the after you remove the screw remove the metal plate & platten glass then move the scanner assembly in the middle portion then you will see a mirrors wipe it with clean rugs then after you clean those mirror remove the 3 screw in the black cover inside the right portion of scanner after you nremove the 3 screw & the black cover you will see 2 mirror wipe it with clean rugs the after you clean the mirrors return all the cover you remove &the platten glass & metal plate then try to make a copy
Posted on Dec 08, 2010
Error code : e030
http://printer1.blogspot.com/2008/11/canon-np6050-service-manual.html Above a service and repair manual, this will show you what to do.
"E030" Total copy counter problem.
May 06, 2010 | Canon NP 6050 Copier
NP6050 Codigo E400
E400RDF to copier communication problem
Recommend to apply to service.
Nov 02, 2009 | Canon NP 6050 Copier
Noise while printing with copier
....whatever it is, understand that you need a technician
Feb 26, 2009 | Canon NP 6050 Copier
Dec 12, 2008 | Canon NP 6050 Copier
Dark horizontal line on canon np6050 copy
Sep 19, 2008 | Canon NP 6050 Copier
Canon NP6050
The E510 is a sorter feed moter problem moter (M1) You can see if the sorter moter turnes if it does not,replace it
If you want a quick cure to get you copying disconnect the sorter remove the communications lead you have to remove the sorter completely and the copier will work.
Thank You
Mar 11, 2008 | Canon NP 6050 Copier
Purging the memory
Hello Jim.I would like to help you but I am not quite sure I understand your need. The Canon NP6050 is an analog device that cannot be networked. And it does not have a hard drive that might retain any information from previous copy jobs. This device does have a small amount of memory to retain custom copy settings, user codes, timers etc, but really no ability to retain and store documents in the manner I believe you are concerned about.So the need to "purge" this device (if I understand your concern) does not apply. I hope this helps, but if I missed your point or can be of further assistance I will do so gladly.
Nov 09, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
189 people viewed this question
old marine
old marine
