Question about AEG 24 in. Favorit 50730W Free-standing Dishwasher
I have a c1 error on an AEG oko favorite 50700 What dies this error mean
  • Anonymous Jan 04, 2009
    I have a same problem too, I think it's the magnetig-valve??
    Can anyone confirm this??
    New Friend:
I don't understand why replies talk about the C2 and C3 errors... The problem is C1! I have the C1 error. I start a programme, it does the draining cycle to check empty then starts filling. MI can hear water entering but it sounds slow at a low flow rate. If I leave it going, eventually the programme stops and the error is displayed: C1 Opening and closing the door allows the programme to continue. I get the error after the various stages of the programme, when it is filling for the next wash or rinse. So it's 4 or 5 times I think during the programme. Now, if I help the filling... When the appliance is filling, I open the door, and poor in a kettle or two of water, then the error does not happen (the fill is within the time expected by the appliance?) So I am thinking one of two things is wrong: 1) I have a flow rate problem BEFORE the water connection to the appliance. E.g. It is blocked somehow. 2) There is something which opens/closes the "tap" within the machine which is causing the flow rate to be low and it does not fill quickly due to that. No idea which of these two, but I did disconnect the hose of the supply and check that water flows quickly from it into a bucket, so I am thinking there is something inside the machine which "opens the tap" and it's not doing a good job of it. Anyone got a clue?
Posted on Apr 07, 2013
5 Suggested Answers
  • 668 Answers
SOURCE: Error code C2 showing on my Oko Favorit
Error Code C2 means drain line totally blocked.
Check drain valve for restriction in pump, check drain line. When there is no problem in drain line then check for a bad float switch or a bad control board . You will get this error even when there is no water in the tub . You can check the float switch with an ohmmeter. It should be open if the float is up and closed with the float down.
Hope this helps .
Thanks for using FIxya.
Posted on Dec 13, 2009
SOURCE: AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Posted on Sep 11, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 500 Answers
SOURCE: Hi there, Do you have a
Hi ntalbany,
The Part Number is 8996461335607.
It can be found here:
http://www.apart4u.co.uk/dishwasher-drain-hose-aeg.html
Hope it helps :-)
If you found this solution helpfull, please rate my answer.
Posted on Apr 27, 2011
Have a aeg oko lavamat 88730 update runs for short time then shows C1 what is wrong with it and how do I fix it and how much
C1 is fault in prewash cycle and means no water inlet.
Could be: vaIve does not open or interruption, flow rate to low.
So, I suggest to check an following parts: water inlet, clean sieve, inlet valve, pressure sensor, wiring.
Dado
Jun 12, 2016 | AEG Washing Machines
I have a oko favorit 4071 doesnt start and display H8 error.
I think this is not the error code. I belive this is hardness of water (could be set from 0 or 1 to 10, depending of model. Read your user manual how to exit the program for adjust the water hardness).
Error code for your appliance depending on model and look like:
i10, i20,i30............ or
C1, C2,C3.............
Dado
Jul 06, 2015 | AEG Dishwashers
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Mar 03, 2008 | AEG Dishwashers
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG 24 in. Favorit 50730W Free-standing Dishwasher Logo
946 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
